Can't find LS1 M/T radiator!
What's the deal with finding a radiator for an 1999 LS1 Camaro with a manual transmission!? All I can find are auto types and they all have an extra nipple that I think hooks to LT1 water pumps. Maybe it's for a power steering cooler. I'm not sure. I know I could put a rubber cap with a hose clamp on it, but I don't want to do that because I've seen those caps blow off in my professional life. I've also seen them get soft and blow out the end. The last thing I want is my wife calling me because she's stuck on the side of the road because of a 50 cent rubber cap!
The only radiator I've found that is correct is part #CU2471. I ordered it from Autozone and when I received it, there was a big hole in the box and the core was damaged. I can't seem to find another one on the whole planet! Junkyard radiators cost $100 or more!
Will a radiator from a 2000-2002 Camaro work? I found one of those from Eckler's Camaro, part #718553 for $285. Hard to tell from the picture, but it looks the same. It doesn't seem to have the tranny cooler or the extra nipple on it.
the best thing to do is order the the 2000 or whichever year is closest. order it, pull yours, and match them up. the AT/MT thing doesnt typicly matter, use brass fittings to plug the holes for the trans cooler if its there. dont use the hose, like you said they can fail.
another thing to consider is that there was a certian year lt1 that had a larger radiator for better cooling, i beleive it was 97, and its a bolt in. not a 100% sure on that though.
I got a manual trans radiator from an LKQ junkyard for $80. I was needing a automatic radiator.
They make these radiators to be as universal as possible, that why they all come with trans coolers. If you don't need it plug it.
If the Autozone one was right but damaged why not just order another one?
Stop being so picky. GM uses the same exact part number for a stick shift car as they do for autotragic car. And that nipple should just go to a different location. LT1s have a hose that goes to the backs of each head and LS1s go to a nipple on the drivers side of the TB.
It seems that was the only one their supplier had. Who knows when they'll get another one? I tried all the other parts stores, NAPA, Advance, etc., and they all carry the same brands. i can deal with the tranny cooler, but I don't like the idea of having to use a rubber cap to cover the extra water outlet. I think all these radiators were actually made for LT1 cars, not LS1's.
Hell I put a spark plug in a heater hose to plug one once and clamped it on the hex, never leaked, never blew out.
If it were me, and I needed a radiator, and all I could find was an LT1 one. I would use a short piece of heater hose with a pipe plug in the end, and two hose clamps. One to hold the hose on the nipple and one to hold the pipe plug in.
I mean take a 1 1/2" piece of heater hose cut square with a sharp knife, two hose clamps.
Only the guys you find putting their head under the front of your car will see it. Not that it looks bad.
I prefer my car to have a reliable, neatly made plug on the BOTTOM of a radiator over leaving it sit in the yard and have the grass grow around it while my 15 years experience as a dealer mechanic uses my resources to come up empty handed in a search for a common radiator.
Seriously, don't take it personally, but do take it rationally.
Answer this, it's almost Sunday.
Do you want me to post a picture of me holding a sign, and a brand new LS1 specific manual trans radiator with no extra nipple by monday?
I guarantee I can do it.
I have plenty of vehicles to drive. I'm not desparate to get this thing on the road. Besides, if I REEEAALLLLLY want to, I can get one of those generic radiators today for $112. I can spare a few days to find the RIGHT radiator.
