Installing vic jr intake. MAP Sensor???
I used the stock one. Mounted it on the firewall above the back of the engine. I took off the orange rubber and used 3/8 hose. I didn't have to make a bracket, I've cut my cowling back so I just cut a notch in the cowling left at the firewall that the MAP would slide on. I'll have pics on my build thread tomm.
Well, i'm not sure what you're setup is now but here is how I did it on my old setup, just ran it directly in the elbow
And on the new setup I needed to run a spacer to clear my fogger and just drilled a hole into the spacer and mounted it in there (you can see the blue labed on the sensor just below the tps sensor)
Forgot to mention earlier... If you're running a throttle bottle or carb make you sure you check the spacing before you get your fittings. Depending on what you've got, you may have to get some low profile fittings.
This motha fuka right her^^^^. haah. That hurts coming from a guy who wants to sell his f-body for a ***** *** corvette. Yea he is right though, I probably wont be able to drive it the way it sits, the torque arm loop is about 4 inchs off the ground. So it will be coming back up another good 1.5 inchs. I will keep that in mind, but im sure it will be ok. Im running the edelbrock elbow with a holley 90mm TB. tons of room .
