It all goes in tommorow....
Old 03-01-2009, 07:57 PM
Caveman1990's Avatar
Default It all goes in tommorow....
Well I finally called up a shop to get my car in to have my new set up put in. I was so damn busy with wrestling that I haven't had the time, state was last weekend so now I'm done for a while and its all going in. The whole deal is:
LE2 Heads
LE2 Intake manifold
22x/23x Custom Grind Cam
Comp Pro-Magnum 1.6 NSA Rockers
Comp Pro-Magnum Push Rods
GM 3.73's
SLP 36lbs Injectors
Vig 4400 Stall Converter
TransGo Shift Kit
MadZ28 tune
LPP Headers and Y pipe
B & M Tranny Cooler
LS7 Lifters
All the gaskets Lloyd Elliot recommended
Anything else that I should buy iin the meantime to have put on?
Old 03-01-2009, 08:00 PM
RamAir95TA's Avatar
Hoowee that's a whole lot of stall! Looks like you have everything mostly covered, but at this point you could probably benefit even more from an electric water pump and a 58mm throttle body.
Old 03-01-2009, 08:07 PM
C5042081's Avatar
she should rip, post some clips when you get it back
Old 03-01-2009, 08:09 PM
i already run the 58mm TB. I will getr clips as soon as I get her back
Old 03-01-2009, 08:22 PM
flyinZ's Avatar
Timing chain?
Sounds like a fun setup
Old 03-01-2009, 08:32 PM
marc97taws6's Avatar
Tell me how your 10-bolt holds up! NICE work tho!
Old 03-01-2009, 08:35 PM
Don't jinx me lol
Old 03-01-2009, 08:36 PM
I'm not trying to man.. You are just in the same position I am.. and my solution was just to get everything done all at once this summer
Old 03-01-2009, 08:43 PM
rusty2198's Avatar
wow thats alot of stall hope it's not over kill. If she hooks and you have descent torque up in the rpm's you stall you just might air out that front end. Good luck with the install keep us informed.
Old 03-01-2009, 09:28 PM
Elliott's94Z's Avatar
Yeah I have a feeling that stall may be a little too much. Don't forget a new timing chain set while your in there as mentioned above by flyinz
Old 03-01-2009, 09:31 PM
Im having the dealership intalling it order a new one
Old 03-01-2009, 10:31 PM
Green3spd's Avatar
May be an obvious, but while you got the tranny out, do a rear seal...
Oh and a coin collection for the 9"...lol
Old 03-01-2009, 10:48 PM
SoxXpupPeT's Avatar
thats going to be Insane! and that stall is huge haha def take lots of pictures
Old 03-02-2009, 01:32 AM
DroppedM6Z's Avatar
time for a....
Old 03-02-2009, 02:04 AM
gregrob's Avatar
Or you could build your 10 bolt...
There are guys with axle tube supports and the rest of the goodies running 500+ through a 10-bolt
Old 03-02-2009, 02:22 AM
Moderator
BizZzatch350's Avatar
You dont have to worry to much in an auto, I have had plenty friends go 10s with their 10 bolts on auto cars. Six speed, which his car isnt, I have had friends break them with cam only LT1s.
Old 03-02-2009, 09:38 AM
2XR95Z28's Avatar
Looks good man, thats alot of money right there lol
Old 03-02-2009, 09:45 AM
Just dropped it off. Hopefully she will be back again in a week
ss.slp.ls1's Avatar
Nice man. Vids...
Old 03-02-2009, 10:00 AM
How long should the break in period be before I can really get on it?
Quick Reply: It all goes in tommorow....
