No start problem: No fuel or spark
Hey I need help getting my car running ASAP. I am not getting any fuel pressure or spark to the plugs. My fuel pump is priming when I turn my key though. It turns over just fine also. Could it be the ICM? The coil and opti are both new, along with the plugs and wires. The only part I did not buy was an ICM. I checked all of the fuses/relays. This problem occurred before I changed out these components.
How did you test for spark?
The pump primed when I turned the key. I disconnected the fuel line that goes to the fuel pressure regulator and primed the pump and fuel came flying out so I do not think it is the pump. I reconnected the fuel line and primed the pump again and check for fuel pressure and got zero.
