Where can transmission pan magnets be purchased??
Old 03-05-2009, 06:31 PM
boola1341's Avatar
Default Where can transmission pan magnets be purchased??
I'm in need of a transmission pan magnet. Is it a certain magnet or will any magnet do? I would rather have the one that comes stock
Old 03-05-2009, 07:00 PM
9000th01ss's Avatar
bulkpart.com has the round ones. Minimum order is $10 though.
Old 03-05-2009, 07:24 PM
LS1Tech Sponsor
performabuilt's Avatar
Radio shack used to carry small square ones I used them a few times they do the job.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-05-2009, 08:18 PM
boola1341's Avatar
will these little things work....http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old 03-05-2009, 08:27 PM
LS1Tech Sponsor
Sure thats about what they have a radio shack
__________________
Call 888-744-6542
Old 03-05-2009, 08:29 PM
boola1341's Avatar
Thanks
Old 03-18-2009, 09:17 AM
Siciliano15's Avatar
would those work on an aluminum trans pan if you put one on the outside and one on the inside on the same spot or would the magnetic field not go though the aluminum pan?
Old 03-18-2009, 11:59 AM
LS1Tech Sponsor
Yes you could do that. And yes the feild will travel through aluminum. However depending on how thick the aluminum is I am not sure it will be strong enough to keep the outter on on there.
I would suggest using some sort of adhesive like JB quick weld and afix the magnets to the inside of the pan.
__________________
Call 888-744-6542
Old 03-19-2009, 09:27 AM
cool. guess ill give it a try and see wat happens then.
Quick Reply: Where can transmission pan magnets be purchased??
