M1 leaking heavily. Lucas Synthetic?
Old 03-06-2009, 07:51 PM
LS1 Eddie's Avatar
Default M1 leaking heavily. Lucas Synthetic?
Ever since I converted to M1 I have a nasty oil leak. I was wondering if I used a quart of Lucas synthetic if it would help this little issue out. Anyone ever used Lucas in their LT1?
Old 03-06-2009, 07:52 PM
Badazz 97 TA's Avatar
fix the oil leak. Do you mean like the lucas "stop oil leak" stuff?
Old 03-06-2009, 08:06 PM
RamAir95TA's Avatar
Why don't you just fix the leak? Where is it leaking from?
Old 03-06-2009, 08:09 PM
lifeisgood's Avatar
prolly front and rear mains. but the car should have had mobil from the start
Old 03-06-2009, 08:47 PM
flyinZ's Avatar
Id just fix the leak. If it was burning it slightly, Id try some Lucas, or even if it had some blow-by..But not a leak.1
Old 03-06-2009, 08:55 PM
nutiger's Avatar
My guess is you have high miles on the LT1? I converted to syn oil to my Caprice when it had 105K miles on the motor. Damn thing leaked like a sieve! I just kept adding oil till it worked into the seals, leaks stopped after about a year!
Old 03-06-2009, 08:59 PM
96capricemgr's Avatar
The main seals almost never leak on these.
Look to the intake, or the WP drive seal as first suspects, then oil filter adapter, opti seal and mains.
M1 is a mediocre choice Lucas a bad one.
Old 03-06-2009, 10:47 PM
LS1 Eddie's Avatar
Ok, I could appreciate all of these responses and thank you. As soon as I get a chance I'll put it on a lift and try to get to the bottom of the leak. The LT1 is not a high mileage. In fact, the motor only has about 4200 miles on it.
Old 03-06-2009, 11:06 PM
kistlerjm9's Avatar
my lt1 did the same thing went right out the front seal, pulled the dampener replaced never had a problem again but i was using castrol german blend to expensive to be on the concrete
Old 03-06-2009, 11:44 PM
buffman's Avatar
Keep the lucas crap away. Fix the leak.
Quick Reply: M1 leaking heavily. Lucas Synthetic?
