M1 leaking heavily. Lucas Synthetic?
Ever since I converted to M1 I have a nasty oil leak. I was wondering if I used a quart of Lucas synthetic if it would help this little issue out. Anyone ever used Lucas in their LT1?
My guess is you have high miles on the LT1? I converted to syn oil to my Caprice when it had 105K miles on the motor. Damn thing leaked like a sieve! I just kept adding oil till it worked into the seals, leaks stopped after about a year!
Ok, I could appreciate all of these responses and thank you. As soon as I get a chance I'll put it on a lift and try to get to the bottom of the leak. The LT1 is not a high mileage. In fact, the motor only has about 4200 miles on it.
my lt1 did the same thing went right out the front seal, pulled the dampener replaced never had a problem again but i was using castrol german blend to expensive to be on the concrete
