Yella Terra #6667 - valve cover clearance???
Old 03-10-2009, 11:21 AM
WernerGMHTP's Avatar
Default Yella Terra #6667 - valve cover clearance???
Hello everyone,
I'm putting together an L92-headed mill and will be using the Corvette-style GM valve covers. Anyone have experience with Yella Terra #6667 (1.7 ratio) rockers and having to mod the valve cover undersides in any way? Just want to know what I'm up against ahead of time.
I'm using a fairly large cam - 0.620+ lift. Valve cover spacers / aftermarket covers are not an option.
Thanks!
Old 03-10-2009, 12:57 PM
Ben Diss's Avatar
I've got a smaller cam (.590 lift), and I did have to knock a few of the high spots down on the covers for clearance. You might find it to be a tight fit. Katech has replacement rocker cover available with more clearance if it somes down to that.
Old 03-10-2009, 01:24 PM
I see. If you don't mind me asking, what model year and vehicle valve covers were you using? I got the latest Corvette ones as they supposedly have more clearance, particularly with offset-rocker heads.
Old 03-10-2009, 06:23 PM
Ben Diss's Avatar
2007 Corvette, LS2, L92 heads, stock covers.
Old 03-10-2009, 09:23 PM
Anyone have any idea whether LS2 and LS3 Corvette valve covers are the same?
Old 03-10-2009, 09:58 PM
TJ
TJ's Avatar
i have a similar situation on a set of trick flow heads.
the valve covers i have, the baffles have been removed.
they clear the valve covers without any grinding.
Old 03-11-2009, 11:19 PM
Haans249's Avatar
If you remove everything (baffles/shielding) on the underside of the valve cover, you will be fine.
Old 03-12-2009, 06:00 PM
WKMCD's Avatar
The LS3 valve covers should be fine. If you run the LS2 you will have to grind on the baffle some but it can be left in place.
I run the GMPP on my L92's w/ YT Ultralights.
Old 03-12-2009, 08:13 PM
Haans249's Avatar
Sexy.
Quick Reply: Yella Terra #6667 - valve cover clearance???
