Yella Terra #6667 - valve cover clearance???
Hello everyone,
I'm putting together an L92-headed mill and will be using the Corvette-style GM valve covers. Anyone have experience with Yella Terra #6667 (1.7 ratio) rockers and having to mod the valve cover undersides in any way? Just want to know what I'm up against ahead of time.
I'm using a fairly large cam - 0.620+ lift. Valve cover spacers / aftermarket covers are not an option.
Thanks!
Thanks!
I've got a smaller cam (.590 lift), and I did have to knock a few of the high spots down on the covers for clearance. You might find it to be a tight fit. Katech has replacement rocker cover available with more clearance if it somes down to that.
I see. If you don't mind me asking, what model year and vehicle valve covers were you using? I got the latest Corvette ones as they supposedly have more clearance, particularly with offset-rocker heads.
