Car won't start.. not cranking over
Battery seems fine. I tried jumping the car and it didn't work. The voltage is fine. All I get is a little click when I turn the key. Could the starter have gone bad?
I was giving the car one last crank before I started checking fuses, then the battery, then the starter. It fired right up. That's great and all, but it doesn't solve the problem because it's happened once before. Does this help narrow the issue down?
Your ignition relay could have been stuck. I've had this problem happen to my wife before. Since I was a long way away, I told her to open the fuse/relay box, pull it out.. tap it on the side a bit, then stick it back in. It worked.
If your fuses all look good, check your grounds. I had this problem and after replacing fuses and the starter and the cables going to the starter, etc... it turned out to be the main ground.
Funny story, same retarded guy across the street saw me working on my car, and when I told him the symptoms he assured me it was the camshaft.
