cam swap help
Old 03-11-2009, 08:44 PM
Nads06111's Avatar
Default cam swap help
Ok so I bought a Hotcam kit from another member on here a while ago. I am planning on installing it this weekend and want to make sure it will work. I have a 94, and the kit is from a different year, all I have to do is switch the dowel pins correct?
Old 03-11-2009, 09:20 PM
Badazz 97 TA's Avatar
yea the cam will work fine in your '94. just measure the dowel pin on the stock cam and compare it to the hotcam. dowel pin length Isnt as important on non vented opti cars. my bet is the hotcam will be longer. you can just grind it down slightly
the only thing im unsure of is if the hotcam has the non vented opti setup in the cam since non vented uses a spline thats inserted in the cam. you might have to convert to a vented opti setup
maybe someone else will chime in....
Old 03-11-2009, 11:32 PM
Nads06111's Avatar
hope i do not!!!
Old 03-11-2009, 11:35 PM
94BlueZ28's Avatar
You can tap the dowel pin in with a hammer. I had to do this for my previous LT4 hotcam. Match the length like stated before but no cutting is required!
Old 03-11-2009, 11:51 PM
Nads06111's Avatar
Yay! so thats it?
Old 03-11-2009, 11:57 PM
the only thing im not sure of since i never seen a non vented unit in person before is i dont know if the hotcam has the spline drive. i dont remember. the hotcam was designed after the LT4 corvette came out in '96(which had the vented opti)
in the bottom right picture it looks like the timing chain sprocket has the splines, not the cam. so thats where im confused
Old 03-11-2009, 11:59 PM
RamAir95TA's Avatar
Non-vented setups use the short pin (~.300") while vented setups use the longer pin (~.720"). If yours is long and you need the short pin, you can cut the pin or tap it in. If you have the short pin and you need the long pin, a machine shop can pull out the pin and reinstall a new one.
Old 03-12-2009, 12:34 AM
Nads06111's Avatar
ok thanks, so there should be no problem as long as i push in the pins
Old 03-12-2009, 01:02 AM
94BlueZ28's Avatar
Correct!
Old 03-12-2009, 03:05 PM
Nads06111's Avatar
Thanks guys, you just got the butterflies out of my stomach haha. wish me luck on the cam swap. any tips?
Quick Reply: cam swap help
