Icm
Icm
Where can i find an icm cheap, there expensive little basterds.. Anyways if anyone knows a website where you can find them cheap shoot it my way. Also if anyone could explain the icm job a little better to me so i oculd help troubleshoot my car that'd help me to
What I would try to do if I were you is to find someone else with a good running LT1. Swap the coil and ICM together. Drive the car and see if it still has the same symptoms. If it does, then it's not the coil or the ICM. If it doesn't, then you know that either the coil or the ICM is bad.
I just bought a brand new coil msd highly doutable that its the coil, i also got some plugs an wires ordered. I'm hoping its the icm, since it only seems to do it while its hot. I'm guessing when the car gets warmed up the icm get hot an malfunctions? But if i can find someone ill try it
