OBD I on 96 Z28
Old 03-21-2009, 10:06 AM
tonskiguy's Avatar
Default OBD I on 96 Z28
I want to replace the OBD II computer with an OBD I in my 96 Z28. Will the original OBD II Harness work with the OBD I computer, or do I need to change the harness as well?
Old 03-21-2009, 10:14 AM
vanilla89's Avatar
I have a obdI conversion on mine and it's just a plug-in deal... No need to change the harness.
Old 03-21-2009, 10:16 AM
Colin91Z's Avatar
^^^ Same here.
Old 03-21-2009, 10:18 AM
creepingdeath94's Avatar
May I ask why you change from OBDII to OBDI? Just curious...
Old 03-21-2009, 11:06 AM
shbox's Avatar
Cheaper to tune and less emission nags.
tonskiguy: you will need to use an OBD-I knock sensor or have a resistor mod done in the PCM to make it compatible.
Old 03-21-2009, 02:10 PM
tonskiguy's Avatar
That's the reason, thanks Shoebox, I was planning on a new knock sensor in the block. Is there any use for the LT4 knock module in the computer on OBD-I?
Old 03-21-2009, 02:30 PM
RamAir95TA's Avatar
Yep. It'll still work fine.
Old 03-22-2009, 12:51 PM
tonskiguy's Avatar
Thanks guys!
Old 03-22-2009, 01:15 PM
96capricemgr's Avatar
I did the resistor mod on my pcm. Running OBD1 in my 96.
If you want to look at Tunercat and Datamaster before buying, let me know. I highly recommend both.
Quick Reply: OBD I on 96 Z28
