Impala SS head gasket
ok lemme get some facts straight.
in order to put them on my car, all i have to do is tell the parts counter guy at a dealership that i want head gaskets for a 96 impala and those should fit right?
(i thought i saw somewhere that is had to be for aluminum heads)
it should bump up my compression ratio to 11:1 right?
so what you guys are saying is that going from a 049 camaro to a 039 impala is going to give you 05:1 and if so what will the 026 head gaskit do.... im going to be puting a bigger camaber head on my car soon. my comp is 10.7:1 with my stock heads and im goint to a 65cc heads and i think with a 049 gaskit it would be 9.8:1 i want more compression
I thought, from what I learned in the thread I made, is that F-Body is .051? Though really I guess it doesn't matter those .002" heh
Stock 10.42:1
.039 : 10.74:1
.028 : 11.06:1
.026 : 11.12:1
65cc w/ .026: 9.65:1
I can't remember which aftermarket one is the .028 now :\ That's posting just waking up for ya! (The CRs are taken from a calculator, so don't worry)
Stock 10.42:1
.039 : 10.74:1
.028 : 11.06:1
.026 : 11.12:1
Stock 10.42:1
.039 : 10.74:1
.028 : 11.06:1
.026 : 11.12:1
Stock 10.42:1
.039 : 10.74:1
.028 : 11.06:1
.026 : 11.12:1
That's using these for specs, which are educated and got me the 10.42 for a stock LT1 and allowed me (with the rest of the LT1 specs) to get the 275/325 in Desktop Dyno.
i just found out my motor has never been decket. so with my 16cc dish and a 56 cc head its 9.9:1.im not digging my compression...my be some one will want to trade short blocks, my low comp forged for a high comp forged
fuel, if you have already had the machinework done to the block and you know the mains are true, why not disassemble the bottom end, take it back to the machine shop and get them to take a four corner measure and deck it?
+1 on that. And if at all possible, maybe see if a bit can be shaved off the heads to make that combustion chamber a bit smaller. Or just shell out for some domed pistons
