What timing chain? Non Vented w/ EWP
Like the title says.
I'm doing a head/cam swap along with a EWP and was wondering about what timing chain I can use for it.
Also, I do not want to swap my opti to a vented because the opti was replaced when I bought it.
Thanks!
Thanks!
hmmm idk, is there a way for me to just change the internals of the opti to a vented opti? Cause I'm looking on summit racing, and I really don't want to add another $300 to my build costs....
Can someone please give me some guidance or something?
I've tried searching, but all I get are forums that are not specific to what year or style they are...
MSD makes a cap and rotor setup that converts it.
http://cgi.ebay.com/ebaymotors/92-94...Q5fAccessories
This is the timing set I used for mine.
http://store.summitracing.com/partde...4&autoview=sku
If you are running the early opti, your only real choice is the stock type set. It is the only type that has the splines to drive the opti. If you don't want to buy another opti and timing cover, that is what you will have to do.
