Rod bolts
Old 03-24-2009, 05:12 AM
Warped's Avatar
Default Rod bolts
I was wondering if you can reuse the rod cap bolts on a Ls2 or are they the TQ to yeild and must be thrown out.
Old 03-24-2009, 05:25 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I wouldn't reuse them and knowing GM they are torque to yield also.
Old 11-30-2009, 06:11 PM
thenewb's Avatar
TTT.... Does anyone actually know? I am looking for a definate answer and not a speculation (I can come up with that on my own )
Old 11-30-2009, 06:47 PM
1QWIKBIRD's Avatar
Here ya go.....
http://www.enginebuildermag.com/Arti...rod_bolts.aspx
Note the recommend an additional 10 degrees of torque on the final pass.
I would just put new ones, unless you popped a cap just to check a bearing. If you're rebuilding, I'd get a fresh set of bolts.
Chris
E-Works's Avatar
buy arp and be done with it forever
Old 11-30-2009, 07:28 PM
stangbeaterz28's Avatar
DO NOT RE-USE!!!! i just went through this process after buying a long block with a broken crank bolt in it... replaced the crank and re-used the rod bolts. After 1500 miles i began to lay into it and with no warning engine went Ka-boom. One rod was completely broken off the crank upon teardown... broken rod bolt! i followed the torque spec and process to the T and supervised by a local racer and engine builder.
Spend 70$ or the 100$ and get the pro ARP. Its not worth it... TRUST ME
Old 12-02-2009, 06:02 PM
thenewb's Avatar
Evidence enough for me. 199 for Katech bolts seems like a better idea then ARP's though
Old 12-02-2009, 06:13 PM
Dickie-311's Avatar
sorry to jump in your thread .. but i have a 2003 lq4 6.0 i'm putting my stang .. and i want to replace the rod bolts with arp's... but not get into a rebuild motor looks good , just want to have the sercurity they are there .. if doing so.. what is the proper way of doing this ? take out 1 bolt at a time then tourque them together ? not to distrub the rod caps , or if i wanted to check the rod bearings for wear .. would this open a can of worms ? ...
