Just installed FAST intake - no brakes
I just installed my fast intake the passed day and i just took it up my drive way and noticed that i had no power brakes! I looked in back and the vacuum line is connected. Now it's in my shop and when i start the car i have power brakes and then sometimes i do not. They usually do not work when i pump them more than three times. Any ideas?
Thank You,
KMMG
Thank You,
KMMG
Yep, its a vacuum issue. Does your AC work right? If not its the small vacuum hose on the back of the intake. If your AC does work then your brake booster hose is kinked or the base is cracked at the booster or intake.
the grommet in the brake booster is probably split!! When you pulled it out was it kinda stuck and hard to get out?? Pull the hose back out of the brake booster and pull the grommet out and look at it, quick and simple
