Drag Racing Tech
Kirkey Pro street vs Economy
Old 03-26-2009, 03:31 PM
Skinny's Avatar
Default Kirkey Pro street vs Economy
Anybody sat in both? Opinions? About ready to buy a seat but I don't have any place local that has either that I can sit in. I see that the depth of the Economy seat is 1.5" less than the pro street, as well as the height. Other than that, I'm really wondering what makes the economy seat so much cheaper.
Old 03-26-2009, 05:11 PM
TJ
TJ's Avatar
pro street all the way!the economy is not comfortable at all, IMO. even if it was a drag car.
Old 03-26-2009, 05:26 PM
Dustin's Avatar
My pro street is way more comfortable than I thought it would be so I would suggest it any day.
Old 03-26-2009, 06:21 PM
Skinny's Avatar
I'll probably be going with the pro street then. I definately think it looks better than the economy seat, but if the looks was the only difference, I might have settled for the cheaper one.
While on the topic, what is everybody using to brace the back of the seat??
Old 03-26-2009, 07:26 PM
fastGBcamaro's Avatar
I am running an RCI seat that is basically identical to the economy drag. It is pretty uncomfortable, and I am planning on going to the pro street kirkeys. I have sat in the pro street kirkeys and they are much more comfortable than my RCI's.
Old 03-26-2009, 08:54 PM
98CamZ28's Avatar
I've sat in both. I currently own the Kirkey Economy seats. If I kept my car, I would definitely put in the pro street seats as they are much more comfortable.
So, my suggestion: Pay the extra $$ and get the Pro Street seats
Old 03-26-2009, 09:34 PM
chvypwr31's Avatar
i like my economy better cause it has the bigger side support.
Old 03-26-2009, 09:41 PM
TJ
TJ's Avatar
you can use pretty much anything. they make some nice adjustable brackets, and several fixed mounts.
at the end of the day its just easy to weld a plate and a piece of tube to the crossbar.
those nuts and bolts were temporary. had the seats in and out several times to get the right angle/length. its locknuted now.
Old 03-26-2009, 09:58 PM
Skinny's Avatar
Is there a bolt going through the seat? I was a little concerned about leaning back against a bolt head.
Old 03-27-2009, 12:58 AM
chvypwr31's Avatar
yea the bolt goes through the seat, youll barely feel it with the cover on,a nd if you wear a fire jacket youll feel it even less.
Old 03-27-2009, 01:26 AM
96LT1355Z28's Avatar
I've got the economy's and I don't mind em, but I've never sat in the pro. It does look better though. FWIW the mount bolts go through the seat also and I don't feel them or the rear brace even with the thin economy cover.
Old 03-27-2009, 11:38 AM
pmbmax's Avatar
Use a carage bolt they are round on the head thats what we use and you cant fill them at all.
Old 03-27-2009, 04:59 PM
TJ
TJ's Avatar
i used button head allen bolts. cant feel a thing.
i know guys that have used regular hex bolts and you really dont notice those.
the button heads are a sure bet, IMO.
Old 03-29-2009, 09:12 PM
wlsmoku's Avatar
pro's all the way - it's like comparing sitting on a flat rock to a lazy boy.
Old 03-30-2009, 02:34 AM
9sec93's Avatar
i have always had the pro street seats and liked them. i never sat in an economy until the other day when i got the pleasure of sitting in 98CamZ28's car which is bad *** but the seat was a little on the uncomfortable side. i could probably tolerate it for just a racecar but if it sees any street time at all it would probably suck pretty bad.
Quick Reply: Kirkey Pro street vs Economy
