which y-pipe?
Old 03-26-2009, 09:03 PM
lwclsswhitetrash's Avatar
Default which y-pipe?
Hey fellas, I need some help!
Just installed LPP headers, and now I need a y-pipe for them.
all the lt1 exhaust stuff from lpp is sold out, so I cant buy one from them.
hooker, dynatech,kooks...what y-pipe will fit these?
I appreciate the help :-)
Old 03-26-2009, 09:11 PM
RamAir95TA's Avatar
Just curious, but how did you get just the headers? Didn't all of them came with the y-pipe? I know mine did.
Chances are no one has yet tried fitting a different y-pipe with them because they always come with one.
Old 03-26-2009, 11:52 PM
there was an option to buy headers only...but arent most y-pipes the same?
Old 03-27-2009, 07:15 AM
multmigs's Avatar
Y pipes aren't universal fit, sounds like you might be better off building your own at a local exhaust shop if you can't get the LPP version...
Old 03-27-2009, 10:04 PM
yeah its just i dont wanna get screwed with some restrictive pipe by some of these shops in my area, id rather save some money and have a pipe designed for my car with performance in mind.
Old 03-27-2009, 10:06 PM
RamAir95TA's Avatar
I know this isn't helping your problem, but why didn't you buy the LPP y-pipe?
Old 03-27-2009, 10:52 PM
00FlowCamaro's Avatar
When I bought my Pacesetter longtubes I went right away and ordered the Pacesetter y-pipe, fit flawlessly. I would look and find an LPP y-pipe man, the fit will be perfect.
Old 03-28-2009, 02:04 AM
S2K
S2K's Avatar
Location: Bristol, TN/Knoxville, TN/Mooresville, NC/Phoenix, AZ
Sounds like the perfect excuse to go true duals.
Old 03-28-2009, 08:58 AM
multmigs's Avatar
X2 on TD... I think the Y pipe is gonna cost you around $200, esp if its SS. After looking at what I have installed with the LPP on my car I'd almost be ready to ditch it and have a custom one made up, if not just make it myself just because I really need one with 2 Cats on it and the way the LPP setup is you can only use 1 and the placement isn't really correct as far as the Cat actually functioning. Also the LPP piece comes really close to the BMR TA relocation bracket I'm using which I had to grind a corner off and again I'm not really happy.
Old 03-28-2009, 11:30 AM
i was gunna go true duals, but plans changed. plus, i dont like the look of not having anything in the factory grooves of the rear bumper
Old 03-28-2009, 04:42 PM
multmigs's Avatar
What does the rear look have to do with anything? get a good TD system and it will look like the stock with dual rear exits...
Anyhow looks like your making something up unless you find a LPP Y pipe to buy....
Old 03-28-2009, 04:45 PM
RamAir95TA's Avatar
Trans Ams have cutouts for the rear tips in the rear bumper. I agree...it looks kind of funny without the tips being there. On a Formula though, it's a bit more acceptable as there are no cutouts for the tips. You Z28 guys have nothing to worry about.
Old 03-28-2009, 10:36 PM
S2K
S2K's Avatar
I think he meant just run the true duals out to the rear; not dump them pre-axle or side exit.
Old 03-28-2009, 11:05 PM
isnt that, uhh, impossible? lol
Quick Reply: which y-pipe?
