Wiring Second Intank Pump
I'm going to install a second pump intank and wanted to know if the diagram I attached looks right. I want the second pump to come on when I activate my master nitrous arm switch. I think I am thinking too hard and making this more difficult than it needs to be but I just want to be sure I get it right.
For your arm switch are would you be able to use a hobbs switch? I'm not how the hobbs switch works, I just know that is what people use with two pumps. Kinda hoping someone could explain how it works. I know Steve has them for sale though.
i would wire it to the n2o silinoid power wire. run # 86 wire to the power wire on the n2o. when you mash the gas and the n2o is activaded it will turn the relay on and send power to the pump
Nevermind guys.. found what I needed on the "2pumps" thread. It's below, if anyone else needs it.
https://ls1tech.com/forums/fueling-i...ick-cheap.html
