RPM range question
RPM range question
I have been reading various places and have done a search with no result. My rev. limiter is set at 6200 I've driven an LS3 with a 7k limit i believe... I see various dyno charts with 65, and 6600 rpm
what is done to allow the engines to safely run at that speed? or is it safe since the LS3 was a brand new vette I would guess it's safe.
some thoughts running in my mind are lighter valves, retainers. roller rockers nessicary? heavier valve springs to prevent float?
Thanks for the help!
How fast you can spin your valvetrain without wrecking it a function of valve / retainer / lock / rocker arm / pushrod / lifter mass and the k (spring rate, lbs/in) of your spring. You can't cycle your valvetrain at a rate higher than its natural frequency. Think Physics 101. A spring with a mass attached to it will oscillate at a given frequency. Reduce the mass, or increase the spring rate and the frequency goes up.
Probably the most common thing folks do is just upgrade the springs to one that is more robust and has a higher spring rate and higher seat pressure. Reducig the reciprocating mass is something else you can do.
But if you have a stock cam that doesn't make power above 6000 RPM, increasing the RPM capability of your valvetrain won't gain anything.
