What rpm do you spray meth at?
Old 03-30-2009, 05:45 PM
STAR's Avatar
Default What rpm do you spray meth at?
How does one determine at what rpm to start spraying meth? Is it dependent on iat, timing or both?
Old 03-30-2009, 05:55 PM
The Beast's Avatar
It's dependant on boost pressure, not rpm
Old 03-30-2009, 08:46 PM
OUTLAWZ RACING's Avatar
9 PSI start and full by 18
Old 03-30-2009, 08:52 PM
Restricted User
98Z28CobraKiller's Avatar
Great question. So the controller operates off of psi in a linear/directly proprtional manner?
Old 03-30-2009, 09:00 PM
Yes I have the snow stg3 and it ramps up to a set full boost psi.
Old 03-30-2009, 09:01 PM
Avengeance's Avatar
You want it to come on according to boost... I use a Honeywell Heavy Duty Hobbs switch. I used to use the one that came with my Snow kit but it looked like a POS.... so I rather put my trust in a better switch.
Mine comes on at 2-3psi and stays on until I let off. Works great.
Old 03-30-2009, 09:08 PM
The Beast's Avatar
Depends on the kit, I personally have a stg 2 snow kit. With that, you select at what psi it starts spraying, and at what psi it reaches 100% spray, like outlawz racing said
Old 03-30-2009, 10:32 PM
thumpstick's Avatar
I actually put together a kit for my car a few years ago for only about $60. Of course it isn't nearly as nice as the ones mentioned above, but it did work. I used a 10psi pressure activated switch that I got from NOS to kick on an industrial rated chemical pump and sprayed into the intake using a dry style nitrous jet and nozzle.
I hope this helps,
-John
Old 03-30-2009, 11:03 PM
The Fugitive's Avatar
where can you find these meth inj kits at? I haven't looked yet because i just read this and thought I would ask (pm the answer). I will start searching around. thanks
Old 03-30-2009, 11:16 PM
'Trust''s Avatar
Mine is set to come on at 6psi then stays on until boost goes below that. I ordered my Alkycontrol kit to come with an independent MAP sensor instead of tapping into the 3 bar MAP.
Old 03-30-2009, 11:56 PM
The Beast's Avatar
PM sent
Old 03-31-2009, 08:25 AM
BigRich954RR's Avatar
With my Alkycontrol kit i set it to turn on at .75 psi and max at 15psi. reason im running it that low i have 11.1 compression on pump 93 with a F1C and i get good intake cooling by about 3-4 psi and max cooling by 9 psi
Old 03-31-2009, 09:01 AM
STAR's Avatar
So it depends on your compression ratio and how much boost you produce. Let's say you produce 5psi @ 3000 rpms on a 9.5 compression engine, when should you start spraying meth?
Old 03-31-2009, 01:44 PM
dpinson's Avatar
it will really be up to the tune/tuner and what is good for your car
each setup will vary as far as what is optimum
Old 03-31-2009, 02:28 PM
The main goal of meth injection is to suppress knock so if your not knocking at 3000 rpm and have all the timing you need then your good with out it
But if your looking for more power crank the boost up or add timing But spray before you have knocking. So if it close to knocking at 5 psi spray at 2-3 psi for a safety net
Old 03-31-2009, 03:17 PM
BadgeZ28's Avatar
full on at two psi
Old 03-31-2009, 03:33 PM
extremetoy's Avatar
is it bad to just add a meth kit and not retune the car?
Old 03-31-2009, 08:52 PM
Domsz06's Avatar
you can always add power adders and what not with out tuning. IT may or may not hurt your car, depends how much you push and use it. I mean what's your car worth to you? If you don't care then do what ever. Personally I would tune after I add anything to my car. I don't have a good ear to hear things, so I'd rather play safe, drive my car longer and have fun longer, as opposed to break something then build new.
I'm not an expert in Meth, but the basic principle the way I understand it is that it cools your air intake and will make you have cooler air, so you can have more hp due to the cooler air. It probably won't hurt one bit to add it and spray it. It sounds like it's there to prevent knocking. Knocking is bad, so if your knocking and you spray then that's good.
I'm sure someone will chime in there, but personally I'd tune it.
Old 03-31-2009, 08:58 PM
Domsz06's Avatar
extemetoy,
Read this.
https://ls1tech.com/forums/forced-in...tercooler.html
Quick Reply: What rpm do you spray meth at?
