Absolute Heads rock! Just back from the track
Old 10-23-2003, 08:06 PM
Super Moderator
Reckless's Avatar
Default Absolute Heads rock! Just back from the track
I built my own motor in my garage. It is a stock 6.0L block (no overbore), 5.7 crank, Comp cam (232/234 .595/.598 112), and Absolute Speed 5.3L heads. The motor has about 30 miles on it. I was hoping for 11.5s during the shake-down runs.
The setup really exceeded my initial expectations. I have no tuning yet! Ran three 11.2s at 119 and my best 60-foot was 1.50! I am quite happy with this. Autotap showed 2-3 degrees of KR during the passes. May be running too much timing for the pump gas and 11:1 CR. Need to get on the dyno ASAP!
Believe the car is good for 10s on the motor and then the spray comes
Old 10-23-2003, 08:09 PM
7 Second Club
Phil99vette's Avatar
Default Re: Absolute Heads rock! Just back from the track
Awesome results, what kind of timing are you running?
Phillip
7 Second Club
10.5 Dave's Avatar
Location: Grove City Ohio/Port Washington L.I sometimes
Cool Todd,looks like the hard work is paying off.
Old 10-23-2003, 08:16 PM
Super Moderator
Reckless's Avatar
Was set up for 29 degrees based on tuning from my old motor. Prolly need to ease it back a little on the 92 octane.
Old 10-23-2003, 08:40 PM
Scalpel's Avatar
That's AWESOME, Todd. Congrats!
Old 10-23-2003, 08:46 PM
Restricted User
2001 Pewter WS6's Avatar
Awsome... I am hoping to try out my new LS6 heads from Jay on Saturday..
Old 10-23-2003, 09:29 PM
98TAauto's Avatar
awesome.. with my TEA heads and 93 gas im running 26degrees... I dont believe we saw any gain from going to 28-29 on the dyno
awesome ET's... it will take ya a few to get the hang of the car then you will be back on track
my first passes this year only saw 11.5@119 on a crappy 1.65 with the TEA's...
im to broke to go back to the track now
good luck man and awesome results.. AS heads rock
Old 10-23-2003, 09:40 PM
Futral's Avatar
Congrats Todd,glad you got it running again and able to race it. Were you able to figure out your missfire problem ok?
Old 10-24-2003, 06:11 AM
boomcase's Avatar
Very nice times, you are making some great power.
Old 10-24-2003, 08:11 AM
Super Moderator
Reckless's Avatar
Thanks Guys \
Alan...the misfire was due to the plugs for two of the injectors. My car has seen so much work, that the wires were just worn out.
If you run into any mysterious misfires in the future, check those injector plugs for good 12v current. My meter showed 12v, but whe the wires was tweaked a little, the voltage would drop to 0. I took the connectors apart and rewired and soldered everything back together. Voila! Misfire gone!
See at the shootout in a few weeks! No spray this time
Old 10-24-2003, 08:14 AM
LSX Mechanic
Damian's Avatar
That's damn good for no tuning and KR Todd. Definately 123+ mph traps in your future with tuning and no knock. Props!
josh
Old 10-24-2003, 08:54 AM
FACE's Avatar
Congrats!
You're really getting my expectations up.. I'm waiting for my 5.3's and cam from Jay, everything should be ready shorty.
Old 10-24-2003, 09:20 AM
Super Moderator
Reckless's Avatar
I made 4 passes total, here are my bests for each category:
60-foot - 1.504 (on my worst pass of 11.32 - hit limiter bad on 1-2)
1/8 ET - 7.137
1/8MPH - 99.75
1/4 ET - 11.239
1/4MPH - 119.96
Thanks Jay! Your heads rock!
Old 10-24-2003, 10:21 AM
Vents's Avatar
SWEET! i just wanted to know the MPH, because yours is such a similar setup to mine. but that makes me smile glad to see that you finally got it back out Todd. cant wait to see what it'll do on the spray.
Old 10-24-2003, 12:07 PM
Super Moderator
Reckless's Avatar
Got dyno time for Sat. Will let you know how things go
Old 10-24-2003, 11:28 PM
GWTFI's Avatar
Well, so much for the 6.0 blocks suck threads. Great job man!
Old 10-25-2003, 06:50 AM
bspz28's Avatar
Awesome Todd .. Jay does great work his heads flat out rock. I was at his shop some time ago when he was working on your heads and he was very happy with the way they came out. 10's are just around the corner for ya.
Old 10-25-2003, 07:51 AM
jfm
jfm's Avatar
It is good to see your hard work pay off,congrats.
Good luck at the dyno and hope to hear you go 10s on that "heavy" motor.
Old 10-25-2003, 08:20 AM
CHRISPY's Avatar
congrats! 1/8th mile mph is indicative of 124mph traps. Are you running a loose stall without lockup?
Cheers,
Chris
Moderator
thechef's Avatar
awesome
