grinding sound after cam swap
Last year when i did my cam swap everything was good. Then about december there was a grinding sound coming from the water pump area.I parke the casr for the winter and today after putting the new pump on the grinding is still there..
Any ideas as to what the hell is up i put a new timing chain on when the camswap was done,could it be bolts backing out in the timing area
need help!!!!
need help!!!!
Could be what 95zsean said, or it could be the cam gear backing off?
If the grinding is pretty loud, then I'd take the water pump off and start the car for a few seconds to see if it still does it. If still grinds then I'd go on and take the front cover off.
well we got it apart and a link of the timing chain had came off and almost rubbed its way through the cover So i need a new timing set and a cover..
Any idea on the price of one of those covers
I have my 94 timing cover if your interested. It's been sandblasted and completely clean. I have a left over crank seal and waterpump seal from my felpro gasket set (not installed). You would just need to buy the one seal for the optispark.
Thanks for the help boys,and for the options of timing covers but i found a good one right here. So it goes on today and hope noothing like this happens again.. Its a good damn thing this didnt happen on the way to the dragstrip this summer lol my motor would have bben done
thanks again
thanks again
well I did a cam swap a while back and had a similar problem. however, I ended up with metal shavings on the drain plug. I assumed it was bearing failure and the car has been parked waiting for the funds to build a forged 355. If you guys think that something might have caused this besides bearings then maybe ill start digging around again.
The only problem I had besides the OP is I had low oil pressure after the engine was warm.
thanks again
thanks again
Holy Sh*t I just realized your from peoria, I grew up in Pekin. Anyway make sure you flush the oil system out good, check to make sure there is no metal in the filter and good oil pressure. Also, Iv'e had two motors go out due to bearings etc. and now I use a prefilter (wire mesh) a K&N filter (a bit pricey) and a filter magnet. It's a bit of money to spend but not nearly as much as building a new motor.
