Disable factory alarm
Forgive me if there are numerous threads on the subject, but I'm tired of the slow/inaccurate search function.
My problem is that I want to disable the factory alarm. I turned the shock sensor all the way down (to the left). I disabled the system by following the instructions in the owner's manual, TO THE LETTER, many times. Still, the car goes nuts when someone goes near it.
I realize that sliding the mechanical locks isn't too much trouble, but it would be nice to lock the doors with the key fob without arming the alarm.
Please help.
Please help.
Ungrounded Moderator
Did you buy it second hand? Maybe there is an aftermarket alarm system installed. There is no proximity sensor on the factory alarm so it could not be triggered by someone going near it - they would have to bang it or open a door.
If it is the factory system and the alarm is sounding randomly (not just when someone approaches the car) then the shock sensor is the most likely cause. Once they go bad you can adjust the sensitivity all you want but the alarm will still malfunction. Disconnecting the sensor or replacing it is the only solution.
I will disconnect the shock sensor. Even so, I assume alarm will still sound if key is used to unlock door, or door handle is lifted even if the sensor is disconnected.
My real question is: Why does the alarm still sound/blink when disabled it as per owner's manual instructions? All other body functions seem o.k.
Thanks
WhiteBird00: Sorry, I was exagerating when I said it goes off when someone goes near it. I meant when it gets touched. It's the factory system.
Thanks
Thanks
I have to believe that you've missed a step in the programming sequence. The instructions are posted in this thread. The programming mode is very fussy about everything being done in the exact sequence listed and without undue delay between steps. You want to set arming mode 1 using the unlock button on your driver's door.
Thanks for the insight, WhiteBird00.
I tried AGAIN to program mode 1 arming method using the unlock button on the driver's door.
Got confirmation with one "ding", but the alarm still goes off.
I'm certain I have a glitch.
I can live with it by working around it.
