Morel Lifters
Morel Lifters
So what lifters are comp cams that are actually Morel Lifters?
I see that the Comp Cam "R" Series ones say that they need to have an adjustable valve train..
Can you use the factory Rocker arms with them?
also who sells them and is good to buy from?
Lunati sells the Morel lifters......
What ones are the lunatti ones they have several...
These ones?
http://store.summitracing.com/partde...N&autoview=sku
These ones?
I bought my Morel Lifters from Thunder Racing. I believe 99blancoss on the forum here also carries them. Whomever you order from MAKE SURE they have them in hand. They are sometimes hard to come by. I ordered mine and waited almost 3 months!!!! Guess it was just bad timing but I was waiting for the weather so no real issue for me at the time!
Yes the link bar eliminates the trays.
Do you need them?? Thats up to you. What rpm and what cam and what springs. Going agressive with dual springs?
The ls7 is just a factory lifter and is nothing special, is not a hi performance product.
The difference between them and a Morel is night and day.
The OEM lifter was enginered with certain spring pressures, cam lobes and rpms in mind.
LS1TECH & Trucks Sponsor
we pretty much always have them in stock as well.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
