Morel Lifters
Old Apr 7, 2009 | 09:18 PM
bigboykilroy's Avatar
Default Morel Lifters
So what lifters are comp cams that are actually Morel Lifters?
I see that the Comp Cam "R" Series ones say that they need to have an adjustable valve train..
Can you use the factory Rocker arms with them?
also who sells them and is good to buy from?
Old Apr 7, 2009 | 09:26 PM
vsocks1's Avatar
No comp cam lifters are Morels that I know of....
Old Apr 7, 2009 | 09:29 PM
SweetS10V8's Avatar
Comp doesnt sell Morel lifters. The "R" series require .002-.004" preload, which takes an adjustable valvtrain to accomplish. I dont even think pushrods have that tight of a tolerance to allow you to use them with stock rocers even if you wanted to.
Lunati sells the Morel lifters......
Old Apr 7, 2009 | 09:36 PM
What ones are the lunatti ones they have several...
These ones?
http://store.summitracing.com/partde...N&autoview=sku
Old Apr 7, 2009 | 09:47 PM
SOMbitch's Avatar
The Cranes used be Morels IIRC... Of course Crane is now out of business......
Old Apr 8, 2009 | 05:21 AM
vettenuts's Avatar
Since other companies buy from several manufacturers (none mentioned except Morel make their own) why not just buy Morels?
Old Apr 8, 2009 | 07:19 AM
dubrado's Avatar
PBM's are morel lifter re=badged also.
Old Apr 8, 2009 | 09:15 AM
I want to buy them, where is a good place to purchase them from?
Old Apr 8, 2009 | 10:28 AM
anyone?? only dealers i found was Speed Inc. and Thunder racing..
Old Apr 8, 2009 | 10:40 AM
vsocks1's Avatar
I bought my Morel Lifters from Thunder Racing. I believe 99blancoss on the forum here also carries them. Whomever you order from MAKE SURE they have them in hand. They are sometimes hard to come by. I ordered mine and waited almost 3 months!!!! Guess it was just bad timing but I was waiting for the weather so no real issue for me at the time!
Old Apr 8, 2009 | 11:33 AM
funny thing...i called thunder racing and they told me that with my setup that i didnt need the morels that the ls7 would be perfectly fine...
Old Apr 8, 2009 | 11:40 AM
Cliff's Avatar
There a shop/store in St. Louis MO. who sales on e-bay the PBM's. I bought mine from him.
Old Apr 8, 2009 | 12:15 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
bigboykilroy you have your rocker specs mixed up in your sig. An eight to one ratio is pretty high.
Old Apr 8, 2009 | 12:32 PM
99blancoSS's Avatar
I've got plenty of link bar morels in stock
Old Apr 8, 2009 | 02:24 PM
haha up i do !! 1.8 fixed !!
now with the link bars it eliminates the need to fun the lifter trays correct?
is thunder correct am i just not in need of them and the ls7 be ferfectly fine?
Old Apr 8, 2009 | 03:12 PM
99blancoSS's Avatar
Yes the link bar eliminates the trays.
Do you need them?? Thats up to you. What rpm and what cam and what springs. Going agressive with dual springs?
The ls7 is just a factory lifter and is nothing special, is not a hi performance product.
The difference between them and a Morel is night and day.
The OEM lifter was enginered with certain spring pressures, cam lobes and rpms in mind.
Old Apr 8, 2009 | 03:40 PM
I have a 224 230 cam
lift is like at .601
Heads are 234 TEA Stage 2 - with dual plat springs
Shifting at 6500
Old Apr 8, 2009 | 03:48 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
we pretty much always have them in stock as well.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Apr 9, 2009 | 01:27 PM
after speaking with several sponsors, they do not recomend morel lifters for my application, thank you all for not selling me something that i really dont need, so i just ordered the "caddy" lifters from Scoggin Dickey, thanks much Jesse !!
Old Apr 9, 2009 | 02:53 PM
99blancoSS's Avatar
Caddy lifters ?!?!?!?!? Have you seen any of the numerous threads about failures using caddy lifters????????
Look, I sell these Morels left and right and certainly dont need you to buy them from me but for gods sake do some research on your lifter choice.
