El torro + which heads???
ok guys since im set on the El Torro cam for a cam swap down the road i was wondering If PRC stg 1.0 LS6's or PRC stg 2.5 5.3 heads would be better for the streets? is there anything that has/needs to be done to the heads to make them work with El Torro? does anyone even have heads with the El Torro cam? sorry for the long post but search is NOT working for me thanx guys
I would recomend Livernois stage III, LS6 heads. The have 220cc intake runners for good velocity and the LS6 castings speak for themselves.
5.3L castings will work but you have to be careful about intake valve choice (2.02 max on unmilled heads) for plenty clearance.
Some valves have thick base (like Ferrea) and reduce PTV by as much as .020
Another good one would be TEA stage 1.5, 5.3L
damn stage II's are already $1400 thats alot lol maybe stage II's(305/235cfm is damn good) but i donno if i could swing $1700 for stg 3's. are the stage 2 and 3's good outta the box with no issues on clearance for El torro Predator?
i still need my original question answered. "will those Livernois stage 2 or 3 ls6 heads outta the box work alright with the El Torro cam w/o clearance issues???"
Another vote for TEA 1.5's.
My girlfriends car has trapped 120mph many times with these heads and a 224/228 cam in her A4 Z/28.
My C5 with our stage 1 CNC heads, 224/228 114 cam, Longtube Headers & X-Pipe, and CAI went 120 mph in the 1/4 mile.
Thank you for your interest, please let us know if you have any other questions.
Regards,
Rick LeBlanc
Livernois Motorsports
the El Torro cam specs are 230/230 .612/592 111 LSA+2 xfi/xer
How would ur stage 2 cam do aginst the El torro? cause i like the specs just think i might want it on a 112 lsa for a sooner peak(street car only M6)
The stage 3 would be in the .07x range
its all good meng
I believe from what ive read when i had the eltorro cam its is more specd for stock heads. I believe predator has a 230 232 he called el torros big brother that he specd for heads that was suppose to make some nasty power
14* overlap (nasty lope), abit less trq below 3500 than El Toro, but more in upper rpms. Trq curve is just as flat as its little brother. Good week end strip cam and it likes 100>150 shots of gogo juice
