anyone running turbo with no intercooler?
Old 04-10-2009, 09:29 AM
Taubr Unit's Avatar
Default anyone running turbo with no intercooler?
Iv seen a handfull of pics of cars with no intercoolers. Granted there on racecars but just thought of it.
Old 04-10-2009, 11:46 AM
trans2000am's Avatar
your IAT'S will be high wouldnt be able to street drive unless you use meth
Old 04-10-2009, 11:50 AM
sujomatt's Avatar
yea dont do it lol
Old 04-10-2009, 12:16 PM
1320's Avatar
The race cars, are probably all running 100% meth.....meaning they run on
m100 as fuel. No gasoline, and big boost numbers ussually becasue of teh fuel, and the cooling the fuel gives.
The street cars.....well, some want to start somewhere. About 100% of them are very low boost, like 5 psi and pretty dangerous as far as it might get hurt factor imo.
Old 04-10-2009, 12:24 PM
aznspeed's Avatar
Just do it right the 1st time..save you money and headaches..
Old 04-10-2009, 12:27 PM
Taubr Unit's Avatar
I'm not gonna actually do it, just wondering how or why they do it. I'm gonna run a huge one just wondering
Old 04-10-2009, 12:46 PM
tim99ws6's Avatar
There is a local guy on a message board that runs twins with no intercooler on his car. Believe it or not, the car hauls the mail! Granted, the car gets heat soaked fast, and he has toyed with meth at the track. Generally, he just runs no meth though.
Old 04-10-2009, 02:07 PM
elias_799's Avatar
why do you not want to use an intercooler ? no room ?
Old 04-11-2009, 01:49 PM
formerly turbo4.8 (2014-06-25)
BLKSSLTT's Avatar
no hes gonna use one... he was just curious why they didnt use them on fullblown racecars
Old 04-12-2009, 01:16 AM
Josh@KY-Turbo's Avatar
No intercoolers are only a good idea on full blown alky race cars. I wouldnt chance it at all.
Old 04-12-2009, 02:05 AM
cracker's Avatar
Nobody's mentioned a blow through carb setup. Granted, an intercooler will always be more efficient than none at all (granted it flows enough cfm) but there are plenty of people going fast, making great power, on a properly setup blow through with no intercooler.
-W
Old 04-12-2009, 01:56 PM
Blow through carbs are a diffrent animal all together. Thats a diffrent school of thought, but I am still well versed in it. The Temps of the Fuel from a carb is not as high as the fuel temps in a EFI situation. Fuel delivery from a carb plays a big role in keeping the IAT temps down. Blow though stuff is fun. EFI is more controlable IMO...
Old 04-15-2009, 10:01 AM
Mavmavv's Avatar
Lots of cars dont run intercoolers, but they are definitely "mild" builds to say the least.
Old 04-15-2009, 10:07 AM
quicksilverado's Avatar
I ran 12 psi on a 370 with no I/C. Cr was about 8-1. Went 11.35@118 with a t67 STS kit. This was in a 4500 lb truck. Drove it on the street as a DD.
Old 04-15-2009, 10:44 AM
Grr
Grr's Avatar
my GN had no intercooler, guy that owns it now still doesnt have one. Cam only LQ4 running 12psi with a S475, never had a problem in the 15k street miles i put on it. Car make mid 600s at the crank
Old 04-15-2009, 11:47 AM
02SSLE's Avatar
Well we have a car that doesn't have an intercooler. It is more of a race car but it runs on 93 pump with 2 meth nozzles. It run 5.60's in the 1/8th @ 129 foot brakeing it leaving off 2 psi. Anyway 60 degrees ambeint with meth the IAT dropped to 45. So I would say if you don't want to run an intercooler then you would need meth. Here are some pics.
Old 04-15-2009, 02:31 PM
Grr
Grr's Avatar
wow badass! I should add that i intended to put a IC on there, but i wanted to get some other things done first and just never got around to it
Old 04-15-2009, 11:18 PM
EARTH MOTORS's Avatar
no intercooler twin 61 pte 402 ci ls2 4l80e in 69 camero 3500lb 10.00 140 mph at LXS shootout
Old 04-16-2009, 07:42 AM
bboyferal's Avatar
Some of you guys are just saying "No intercooler here," but not saying anything else...
Specify what fuel, meth/no meth injection, etc. so it could make sense.
I run both FMIC+methanol...
Old 04-16-2009, 07:55 AM
BoostnTBSS's Avatar
No i/c here
well blow thru e85 10.5-1 comp. ls6 and it loves the boost... will be spraying meth pre turbo and will spray lots cause i am a huge fan of draw thru turbo setups!!!! i love frosting the intake on 90+degree days..
Quick Reply: anyone running turbo with no intercooler?
