H/C/I Ls1 runs 7.7 in the 1/8 mile whats wrong?
Old 04-11-2009, 12:11 AM
blackhawk98's Avatar
Default H/C/I Ls1 runs 7.7 in the 1/8 mile whats wrong?
My 98 TA has the following mods and seems to be running good but i know my times should be faster....
7.7 @ 1/8mile 88mph with a 1.63 60ft.
Ls6 Patriot performance heads
Torquer v2 cam
ss4000 yank converter
stock 10 bolt with 3.23
Ls6 Intake
Built Transmission
stage 3 shift kit
full exhaust
Full weight
stock suspension
What could be the problem maybe the suspension or could it be the mail order tune?
Old 04-11-2009, 12:18 AM
silverbeast's Avatar
hmm, that is a little strange. The 60' isnt that bad but the mph isnt there that backs up the power you should be making. The car needs more gear but it still should trap over 88. Im thinking either your tune is way off or you have tranny issues.
Old 04-11-2009, 12:45 AM
jsteele90's Avatar
damn when my car was just bolt ons it ran a 7.80@88 with a 1.706 60ft. get a real tune and some suspension
Old 04-11-2009, 01:26 AM
jetlag's Avatar
I don't think suspension would be that big of a problem...My car pulls 1.45s easy with Eibach Sportlines and all stock suspension except LCA relocation brackets.
But, I agree, get a real tune.... have you ever had it dynoed?
Old 04-11-2009, 10:32 AM
no i was waiting for my nos to get it dyno tuned...I just got the tranny rebuilt...I put the trango hd2 shift kit and cant feel the shift unless i get on it is this normal with a big stall converter.
Old 04-11-2009, 11:49 AM
TABBED 5.3's Avatar
yes a bigger stall will "soften" the way the shifts feel. other than that, gears, no tune and full weight are the problem
Old 04-11-2009, 12:24 PM
01_ram-air's Avatar
I'm thinking that it's in the tune as well. Something is not right. Suspension work will help the 60' but your 60' times are not Horrid... but could use some improvement.
Old 04-11-2009, 12:41 PM
jasonsblkws6's Avatar
Problem has to be in the tune with either the shift points or converter lock up points or it has to be the tranny.
Old 04-11-2009, 01:27 PM
yeah thats what I was thinking because from low punch it stick at 5000 for a bit then it will start pulling and sometimes from a 70 punch it wont downshift at all...it will go to like 4000 then back to lockup.when i slow down and try it again like at 65 it works fine.
Old 04-11-2009, 03:39 PM
99_Z28's Avatar
You have alot of mods for not having a real tune, your 60' is good...I ran a 7.7@89.8 1.77 60' on junk parts untuned.
Old 04-13-2009, 11:38 AM
Well ima go get it dyno tuned soon anyone know where a good dyno tune place is around tyler tx or east tx?
Old 04-13-2009, 02:31 PM
thunderstruck507's Avatar
there is a shop in longview I'm not sure if they're a sponsor so you can pm me if you'd like to know and can't find it on your own
I've heard good things about them, and will either be letting him do my real tune or go to OKC, there are a couple good shops up there
Old 04-16-2009, 09:21 PM
Im dropping my car off for the tune in the mornig...hopefully this fixes my prob...thanks
Quick Reply: H/C/I Ls1 runs 7.7 in the 1/8 mile whats wrong?
