96 SS won't go into first gear?
Old 04-11-2009, 09:19 PM
WH97Z's Avatar
Default 96 SS won't go into first gear?
Switched out the pcm from an obd ll to an obd l so i could tune with tuner cat and now the car won't go into first or hit overdrive. Doesn't matter if i manually shift it or leave the car in drive. Any Ideas?
Old 04-11-2009, 11:12 PM
Village Troll
SS RRR's Avatar
Is the OBDI PCM for an auto or manual transmission?
Old 04-12-2009, 01:53 AM
WH97Z's Avatar
the obd l pcm is for an automatic. i worked fine in my other car which is a auto. I reinstalled the stock computer and it shifts in to first and overdrive just fine?
Old 04-12-2009, 11:42 AM
ThoR294's Avatar
um dont you have to change wiring and stuff you cant just remove and replace the PCMs from OBDI/OBDII?
Old 04-12-2009, 03:27 PM
WH97Z's Avatar
It installs just the same. No wiring is needed. You have to delete some stuff in the tune thats it.
Old 04-12-2009, 07:24 PM
Dmaleck's Avatar
Maybe it came out of a caprice or some other lt1 car and didnt have the same tranny? just a guess, im not sure if they changed trannys at all.
Old 04-12-2009, 07:30 PM
WH97Z's Avatar
Ok, will check into that. The only thing that puzzles me is i have done this to three other cars and never had a problem?
Old 04-12-2009, 07:34 PM
Village Troll
SS RRR's Avatar
You can always send it to a mail order tuning place to have it analyzed or reflashed.
Quick Reply: 96 SS won't go into first gear?
