LQ4 yr? TH400 spacer needed?
Old 04-17-2009, 02:30 PM
djsanchez2's Avatar
Default LQ4 yr? TH400 spacer needed?
Hey fellas,
I am pretty sure the LQ4 I have is a 2003, which means i should only have to use the regular LS1 flexplate to mount a TH400 to it. Or is it the later ones that need the spacer? Here are some pics of the
casting #'s
Block dating#
Rear crank
Old 04-17-2009, 02:42 PM
SICKSS/Z28's Avatar
i have a stock th400 bolted up to my iron block rite now no spacers
Old 04-17-2009, 02:44 PM
djsanchez2's Avatar
Did you use a flat or dished flexplate, and what yr engine??
Old 04-17-2009, 02:50 PM
12secSS's Avatar
I have a 2003 LQ4 in my 2001 SS, use the LS1 flexplate and not the LQ4/4L80E flexplate. Only the 1999-2000 LQ4s used the longer crankshaft, the others (LQ4s) used a spacer in between the (flat) flexplate and crankshaft for the 4L80E. The LQ9 used with 4L60E used the LS1 (curved) flexplate.
Old 04-17-2009, 02:56 PM
ctd450's Avatar
I have an 01 LQ4 bolting up to a 700R4. Do I need to change the flexplate to an older style with a spacer or can I keep the stock LQ4 plate?
Old 04-17-2009, 04:39 PM
billyflantos's Avatar
my 2002 6.0 came with the spacer...
Old 04-17-2009, 04:48 PM
Bo185's Avatar
**BAD LINK** now
Old 04-17-2009, 05:41 PM
12secSS's Avatar
You will need the spacer and 6.0L/4L80E flexplate. The flexplate is the same one used from 1999-2007 on 6.0L with a 4L80E. The crankshaft in 1999-2000 6.0L had an extra thick flange to space the 6.0L/4L80E flexplate properly, which was different from the LSx flexplate. In 2001 GM used only one crankshaft and incorporated a spacer for engines used with the 4L80E.
That is because your 6.0L was mated to a 4L80E.
That is a good link.
Old 04-17-2009, 06:03 PM
ctd450's Avatar
Will the bolt holes for my 700R4 converter line up with the flex plate or do I need to egg out the holes a little?
Engine is from an 01 yukon denali if it makes a difference.
Old 04-17-2009, 07:59 PM
383lt1impala's Avatar
I have the hughes crank spacer for my th400. Is that all I need? Or do I add longer bolts? I'm going to be bolting it together soon and I want everything to be perfect.
Old 07-01-2009, 07:22 PM
smokin97's Avatar
I have a 03 5.3L out of an Envoy, what flexplate do I need? Ill be using a Th400 with an Ultra Bell. Just a regular LS1?
Found these,
http://www.exoticperformanceplus.com...html?item=1090
http://www.pirate4x4.com/forum/showthread.php?t=751522
http://advanceadapters.com/product/3...smissions.html
Old 07-02-2009, 12:04 PM
Bo185's Avatar
The stock 6.0L flat flex plate will work as well.
Old 07-03-2009, 12:54 PM
Shon Herron's Avatar
I have several crank spacers if needed, just PM me. we had them made when doing a couple of Jeeps that use 5.3s and TH400s.....
Old 07-03-2009, 01:55 PM
Bo185's Avatar
Spacer from GM parts direct or local dealer
GM PART # 12563532
CATEGORY: Spacer
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $52.86
OUR PRICE: $31.34
BOLTS
GM PART # 12563533
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $6.86
OUR PRICE: $4.06
Flex plate http://www.crateenginedepot.com/stor...3ykj7OraIvNr7h
Spacer http://www.jegs.com/i/GM-Performance...63532/10002/-1
http://www.crateenginedepot.com/LS1-...-P1343C19.aspx
Old 07-03-2009, 07:47 PM
72Obsessed's Avatar
I just bolted mine up with all the same parts and I needed to drill new holes. I used 1 existing and had to make 2 new.
Quick Reply: LQ4 yr? TH400 spacer needed?
