LS6 intake installation. Urgent help please.
Well I'm tearing this thing apart and I'm having a ton of trouble.
When I deleted my AIR I had this clip with an electrical connector on the side and I have no idea what it goes to.
It has two vacuum hoses, but I can only find one, that connect into it and an electrical connector.
I think I removed one with the AIR, but I can't remember.
Ah! Needing some help guys!
Thanks!
Thanks!
thats for the air solenoid if i read your description correct, those tow little vaccum hoses go into it, my suggestion is get a vaccum cap and delete those two.
the back of the intaqke only needs the large brake booster hose, the map sensor, and the smaller vaccum line that goes into the wire harness for the ac
i was actually curious about hat as well. im in the middle of my install as well. so i just block off that second smaller port on the back and only need the brake booster cable?
where the hell are you most car id say 97 and up have both
hi guys, i have a question about ls6 intake manifold installation, i figure i just ask right here instead of making a new thread.
i'm not mechanically inclined and any help would be appreciate
my car is a 98 camaro ss,
i believe my car has EGR/AIR, the guy that i bought the ls6 IM said that it doesn't have EGR, and i think all ls6 intake doesn't have EGR except for one that has been modified, my question is,
*what parts that need to be prepared before doing the swap?
*how long the installation usually take? (since i'm pretty sure i'm going to do the EGR/AIR delete thing)
*Will my Ported Jantzer TB fit the ls6 IM?
*Would i have any problems with my stock fuel rails?
if anyone can direct me to a thread that has info about my question that'd be a great help
Thanks
Ray
Thanks
Ray
