LS6 intake installation. Urgent help please.
When I deleted my AIR I had this clip with an electrical connector on the side and I have no idea what it goes to.
It has two vacuum hoses, but I can only find one, that connect into it and an electrical connector.
I think I removed one with the AIR, but I can't remember.
Ah! Needing some help guys!
Thanks!
the back of the intaqke only needs the large brake booster hose, the map sensor, and the smaller vaccum line that goes into the wire harness for the ac
I can confirm it is part of the AIR system.
But I threw a check engine pretty quickly.
Any idea what it might be?
She is GREAT on power, shifts perfect, runs perfect, and idles GREAT!
And I did break my oil pressure sensor thingy, but I replaced it.
You NEED the MAP sensor, brake booster, and that "T" thing.
Thanks for posting it.
i'm not mechanically inclined and any help would be appreciate
my car is a 98 camaro ss,
i believe my car has EGR/AIR, the guy that i bought the ls6 IM said that it doesn't have EGR, and i think all ls6 intake doesn't have EGR except for one that has been modified, my question is,
*what parts that need to be prepared before doing the swap?
*how long the installation usually take? (since i'm pretty sure i'm going to do the EGR/AIR delete thing)
*Will my Ported Jantzer TB fit the ls6 IM?
*Would i have any problems with my stock fuel rails?
if anyone can direct me to a thread that has info about my question that'd be a great help
Thanks
Ray
