removing the engine
Old 04-19-2009, 09:02 AM
97badass's Avatar
Default removing the engine
ok i know ive seen it on here before how to pull the engine out the top insteac of dropping it out with the k member. before you start with the search comments im on my cell looking. any info or a link would be appreciated greatly. and a link to the heater and a.c delete. thanks
Old 04-19-2009, 09:14 AM
RamAir95TA's Avatar
http://www.michiganspeed.com/enginepull/index.html
https://ls1tech.com/forums/lt1-lt4-m...x-removal.html for the heater box.
A/C removal is fairly straight-forward - just remove everything. You will need an A/C delete pulley. Don't forget to discharge the system first!
Old 04-19-2009, 11:10 AM
SoxXpupPeT's Avatar
i had removed it from the top but i had Everything off. it worked out alot easier for me and the amount of time i had to work on the car each day. it would be alot easier pulling it from the bottom tho if you have the time/space
Old 04-19-2009, 11:34 AM
highflyin's Avatar
If you have a lift then drop it all out the bottom. If you dont then pull it out the top. I have done it both ways and dropping everything out the bottom is easier.
Old 04-19-2009, 05:01 PM
97badass's Avatar
ya i know its easier to drop it out the bottom but i dont have a lift or a place to do that. thanks for the info guys.
Old 04-19-2009, 05:32 PM
RamAir95TA's Avatar
Whether you take it out the top or the bottom, you still need a hoist.
Old 04-19-2009, 06:04 PM
97badass's Avatar
i have a cherrypicker just not a lift transmission is already out of the car. from what i can tell i just need to take the hood off and disconnect the electronics and move the motor forward where the radiator was and straight up?
Old 04-19-2009, 06:43 PM
SoxXpupPeT's Avatar
take the hood off disconnect everything. pull both radiators and if you can the harmonic balancer (itll give you alittle more space but i didnt for when i did it) and the plastic piece for the cowl next to the windshield wipers. there are afew clips that you pull out and its ok. i dissconnected the bolts for the mounts off the block itself and lifted it up alittle and slid it forward. it was real east but i had 2 sets of hands to help
i also made this bracket so it kept it low profile to the block so i could swing it under the cowl. idk if you could use anything else. but i work at a shop so it wasnt so bad
Old 04-20-2009, 11:47 AM
saylorZ28's Avatar
i had my engine out from the top in just under 3 hours by myself and didnt scratch anything ... but i will need help mating it back up to the tranny
Old 04-21-2009, 06:44 AM
97badass's Avatar
so the intake has to come off also? before i can take it out through the top?
Old 04-21-2009, 08:13 AM
94BlueZ28's Avatar
I just removed my engine and tranny intact from the top last weekend and I didn't have to remove the hood at all. It's pretty much straight forward on the removal. Take your time and have someone help you push the cherry picker back while another guy holds onto the motor so it doesn't bang up your engine bay.....cake
Quick Reply: removing the engine
