First time mityvac user here. Hate to start new thread.
Ok guys my clutch hydraulics have plagued me ever since my engine was put into my car. It wont go into first easily at all and grinds like nobody's business. I just bought and installed the Tick adjustable MC and still grinding. I was told I still needed to bleed the system. Well I went and rented the mityvac read the instructions as I've never used anything like it before. I put it into place and started squeezing. Never saw any bubbles but as I was squeezing the plastic line leading from the vac to the clutch reservoir collapsed. I wasn't even at 15" of vacuum yet.
This **** is getting on my damn nerves, so some help on how to use this damn thing would be great.
I have a Tick m/c as well. Those take so much fluid that you can gravity bleed them. I also have a Mity-vac and never had much luck with it.
Everytime I've installed a new master cylinder, I've bench bled without the Mity-vac. Once I have it bench bled, I just hook it up to the slave pump the peddle a few times and that's it.
After much headache and pulling the tranny out about six times, I found something that works for me.
The best formula seems to be, bench bleed the m/c regardless of what type it is or get a pre-bled GM unit.
Also, why not try lengthing the the m/c rod just a little bit.
Sometimes dirty boiled over fluid reaks havok too.
I just put in a new LS7 clutch kit too. So far so good.
Some say open the bleeder valve and than push or some say push the peddle down and open bleeder. The both work as long as you don't let the peddle back up while the bleeder is open.
I hope you get that beast fixed.
