electric fans for a body
Old 04-22-2009, 02:07 PM
ral_fradet's Avatar
Default electric fans for a body
im putting a ls1 into a lemans and i was wondering which electric fans fit the best, ive heard intrepid fans work but i dont really want to buy one before i know it will fit, any help would be great
thanks
Old 04-22-2009, 04:34 PM
71 chevelle's Avatar
I would like to know as well. Can pics be posted as well with any mods that were done.
Thank you.
Old 04-22-2009, 05:06 PM
ryanvv355's Avatar
I used 2 Denso AX168000-3240 (IRRC) fans with the cable tie things to mount it. The fans are absolutley huge and the two take up the entire OE radiator. I have them both set to come on at 185* with a 160* stat. I have not seen temps higher than 191* yet.
I remember being told they came out of a Super-Duty Ford, but now that I think about it those trucks dont even have electric fans. This was in 2002.
Will try to get pics up tonight.
Old 04-23-2009, 10:56 AM
Eric Anderson's Avatar
For my 68 Cutlass I used Electric fans from a Dodge Concord. I'm not sure of the year but I could find out. Send me a PM.
https://ls1tech.com/forums/conversio...se-lookup.html
#11 on this link has info on the hoses that I used.
Old 04-23-2009, 11:06 AM
bczee's Avatar
I am using two SPAL Fans with the standalone SPAL Controller.
Many are using the Ford Taurus which seem to move a lot of air and can be found in may junk yards cheap.
Old 04-23-2009, 11:36 AM
pist0lpete's Avatar
I am using the fans from like a 95 intrepid. With wise they are a perfect fit on my stock radiator. Height wise they are maybe an inch short but they move a ton of a air and once the come on my temps stay at 200 with the stock thermostat. Need to put a 160 in.
Old 04-24-2009, 05:48 AM
TOOSLO5's Avatar
Using dual Spal's with a Spal controller like bczee is. The Spal PWM is an additional cost but it varies the fan speed based on the engine temp. This is a nice feature in stop and go traffic in August. The fan is not constantly cycling on an off. I run off of the primary fan only and when at the track i use the secondary fan to cool down between passes. A buddy uses the "tortise" fans on his Skylark. He is running a F1C procharger and a HUGE intercooler without any issues. The "tortise" units can be picked up fairly cheap.
Old 04-24-2009, 06:52 AM
forcd ind's Avatar
im using, 2- 13" spawl fans, and an AFCO a body conv. radiator-i had the fans left over from a prev project, but to buy them new would be exp.
i run an intercooler along with a procharger, and it cools fine-one fan uses a relay and a sensor, the other i can operat man. with a relay and switch-i might switch to an adjustable thermo. for the main fan, kicks in higher than i would prefer
Old 04-24-2009, 07:18 AM
71Convertible's Avatar
I'm using fans from a circa 1995 Ford Windstar, they fit very well size-wise on the stock radiator.
Old 04-24-2009, 08:52 AM
sbsrkh's Avatar
x2 on the Ford Windstar. I used them for my small block in my chevelle and will keep them with the LS1. Notch for the top hose, trim a little on the right and make a couple of small "L" brackets for the bottom. Got some pictures here:http://s469.photobucket.com/albums/rr60/sbsrkh1/Pulley/
Old 04-24-2009, 03:05 PM
bczee's Avatar
One other feature that is nice is that the Spal PWM controller can set the temp manually on the fly so. You don't have to have your PCM tuned for fan/temp settings. I can change it anytime for the summer or winter driving.
It also can be manually activated with a switch or when the AC comes on by using the blue wire on the controller.
To set the temps low and high speeds, Just push the buttons at the temp you want the fans to activate.
Old 04-25-2009, 12:29 AM
ral_fradet's Avatar
what are the dimensions of the windstar and intrepid fans?
Old 04-25-2009, 06:21 AM
forcd ind's Avatar
hey BCZEE-not to hijack this thread, but do you have a part # for the controller
Old 04-25-2009, 11:37 AM
bczee's Avatar
"FAN-PWM" is the SPAL Controller part number, search the internet or ebay for the best price.. about $89.95 retail.
http://www.spal-usa.com/fans/automat...es/fanpwm.html
It can control two fan if setup with the optional relay, I was able to use the stock OEM LS1 sensor as input to the controller.
Old 04-25-2009, 03:36 PM
TOOSLO5's Avatar
You may be able to find this PWM on evil bay but Spal has a new unit out which replaces this one. I have this one on my car now but the primary fan controller is shorted internally (my fault) and I have the new unit sitting in the garage ready to install. The unit bczee linked worked great for a few years till I screwed it up during some harness mods I was making. This was of course after a few to many during a late night thinning out the stock harness.
Old 04-27-2009, 12:33 AM
RYU
RYU's Avatar
I'm using the Ford Taurus fan (The robocop years ). It moves a lot of air but it is only a single fan. It also has a high and a low trigger (3 wires). Not exactly sure how I want to wire up the 3 relay fan switching system on the LS1 PCM. I'll figure it out when I get to it.
Be careful on this... the high side circuit draws A LOT of current. I toasted a Bosch 40amp relay in the middle or S. California rush hour traffic. I'm currently only using the low side now and still am able to stay below 190 D. I don't think you will need the high setting but might be good to wire it up anyway.
I'm using a stock copper radiator equivalent.
Quick Reply: electric fans for a body
