how do i lift the front wheels
hey all, what would your opinions be on the minimum it would require to take a stock lt1 6spd trans am and make it lift the tires, or even just one.
i figure at least:
12bolt or 9"
wide tires
good clutch
interior weight reduction
remove front sway bar
heads and cam
anyone done it on just these simple things? or does it take a lot more...
i figure at least:
12bolt or 9"
wide tires
good clutch
heads and cam
If that is your goal then just get three things: 4.56s, slicks and skinnies, and a shot of nitrous off the line. It'll lift the wheels...well, once at least. Bring a trailor.
The question is, why? Its not the fastest way down a track, and the landing is hell on parts. Wheelies can be very expensive.
rally you gotta worry most about your suspension
and a tire
get it too hook then spray it and you should have it
a set of adjustables up front
some cheap comp eng drag shocks out back
a decent LCA and relocation barackets
some subframe connectors
and some slicks and skinnies
spray it and hold on
a 4.11 or better gear would help too
it will get it up a little
and a tire
Internet Mechanic
https://ls1tech.com/forums/eastern-m...ay-new-pb.html
Here is my car, it is a LSX which helps with weight over the k frame and it makes around 380, but its a heavy car. Take a look.
i figure at least:
12bolt or 9"
wide tires
good clutch
heads and cam
i figure at least:
12bolt or 9"
wide tires
good clutch
heads and cam
You need to be able to dead hook and have a good sus thats dailed in.
You have to rember you dont want to wheelie more than a couple inchs really or it will start to hurt your times.
Friend here in the KC area, could get a few inches of air under the fronts. He had Heads/Cam. The suspension was dailed in and the Drs were hooking. The was a full wieght car btw. Good Luck.
