Track times
Track times
Well, first off thanks to Keith,Josh and the rest that helped me with the car to get it ready.We were at the shop till 9:30 last night.
Car is the shop car that is a 99 TA,A4.
Parts
FLT level 5 tranny
Midwest Fab 9 rear with 3.73's
Yank SS 4000
American Racing 1 7/8 headers,no cats,Magnaflow cat back
LS6 intake,underdrive and 231 Cam
Scales were closed,guessing around 3600-3700lbs
DA was 2000' at 11am
Best run was
1.60 60'
11.86 at 112mph
I was ok with the time since the car dyno'd 370rwhp.Now we'll do a few changes to get power up to 400-410 were it needs to be.
Parts
FLT level 5 tranny
Yank SS 4000
Best run was
1.60 60'
11.86 at 112mph
nice run for the 1st time out! Makes me want to buy an automatic and drag it lol
How do you find out the DA? did you have one of those hand held weather stations? I want to find out what it was for Saturday.
Great day the the track Don, and great to see you having some fun
Ted was flat out robbed in the first round, but atleast we can say we are both ahead of him in points (for the next few weeks anyway)
See you at the next race! or earlier if I can scounge up some $ for a set of headers
Don your car was running great for the first time out. Little more weight reduction and tweaking will get you where you need to be.
Great to see you and Vinny get through the 1st round even though you guys arent quite dialed in yet.
Nate - a couple of the guys have weather stations that they are kind enough to share the results from.
It was cool to see the 2 toughest cars end up in the finals against each other for a change - even if they are sandbaggin old school race cars beatin up on a bunch of street cars.
I was actually kinda psyched to get the 67 big block mustng in the 1st round. I wanted to take him out sooooo bad.
Internet Mechanic
It's an automatic car, I would expect it to do mid 11's with the mods. With cooler air from an nov/dec atco run should put it 2 tenths quicker. DA does make a huge diff as long as the car can still hook which again for a auto should not be that much of an issue. Congratz on the time. Your not far off from Cage requirements at least if you were in a NHRA track.
I still think about a built 4L60e or a 4L80e swap considering how well my mis-matched LT1 383 car did against alot of stuff on the street and the track. We will see.
Nice Don!
Seriously that car with a stall and 9" put down 370 on a dyno jet. That's pretty impressive, the trap speaks for itself, especially in the heat.
Were you using nitto's? How do you like that Yank converter?
Fast intake and a little weight reduction you could run the 11.5 bracket before you touched the heads.
Wish I lived closer to you guys, you get to do all the fun stuff and all I get to do is hear about it
A 400hp stalled A4 is a pretty fun street car. Don was always the guy everytime he worked on my car said an auto was cheating, and now look lol
Internet Mechanic
When my car was similarly modded, slightly smaller stall and cam it made 374 on the dyno (dynojet) and I ran a 11.9 @ 111-112, in probably lower temps than what Don had. You gotta remember the car weighs almost 3700lbs, thats' really pretty good for a cam only super streetable car in the heat. Cooler air makes a huge difference, I agree a good .2-.3. or so.
Like said I had a auto and if I lived closer or raced more often I think one would be going back in. Dont mind me, im thinking out loud.
Nice Don!
I've got some parts coming that will put me past 11.5 in the heat
If I get bored the C5R 427ci motor will be put in.
The converter did good but my 10" ET street's didn't like it.The 60's were the best of 1.58 and worst of 1.62. I had no test time to see where the magic stall is but it can be footbraked to 3800rpm.
I want a converter than can tear my stomache out
8 second mod
those numbers seem to be pretty close to where they should be.
the couple cam only cars i have done run in the 11.4-11.6 range but they are running threw stock 10 bolts.
chris has my custom 232 cam in his car, pascetter headers (junk) a cut out air lid, 3:73's in his 10 bolt, MT et drad radials full weight car with all options, and he went 11.5 in ok weather. not great, but ok.
