Trip odometer is not working
Old 04-26-2009, 10:25 PM
hyperzone's Avatar
Default Trip odometer is not working
I only noticed it the other night and haven't had a chance to look into it. Anyone ever had a trip odometer go bad? Mine is moving slowly as if its getting stuck or something. It rolls 1-5 miles for like every 15 I drive. Main odometer works good as far as I can tell. I'm sure someone has taken apart the cluster and seen the internals... Any clue why its all of a sudden crapping out?
Old 04-26-2009, 10:28 PM
Moderator
BizZzatch350's Avatar
My odomoeter works but my trip never did, I hear its a broken plastic clip inside.
Old 04-26-2009, 10:55 PM
shbox's Avatar
If it is like mine, the gear is cracked and wont' turn the shaft any more. Mine used to run up to 9/10, then couldn't grip enough to click over to the next mile. Eventually it just stopped. I fixed it once with some glue, but that eventually failed (I guess from the heat the dash takes in the summer sun). I wish I knew of a place to get a replacement gear.
The following users liked this post:
Bmoore34 (12-02-2019)
Old 04-27-2009, 08:58 AM
LaVy's Avatar
my trip odometer doesn't work either.
Old 04-27-2009, 10:22 AM
djjab57's Avatar
lol same here , no worky
Old 04-27-2009, 12:29 PM
ss.slp.ls1's Avatar
Mine's digital.
Old 04-27-2009, 12:51 PM
Bad_tx_Z28's Avatar
niether of mine work. Trip or odemeter. I have been trying to find another on, but no luck.
Old 04-27-2009, 01:21 PM
shbox's Avatar
Originally Posted by ss.slp.ls1
Mine's digital.
Mine has digits.too. They just don't change.
Old 04-27-2009, 01:39 PM
mysticdemon's Avatar
yea my trip is broke as well. Sometimes it'll go for a little bit and then eventually stop and other times it wont even start counting.
Old 04-27-2009, 01:41 PM
ss.slp.ls1's Avatar
Higher resale value f.t.w.
Old 04-27-2009, 04:33 PM
well it already has 150k and i probably wont be selling it anytime soon. Especially after all the money i dump into it this summer haha
Old 04-27-2009, 08:50 PM
Raven97's Avatar
Mine is digital but it has a short and if you hit a big bump or let the car sit for a while it resets to zero
Old 04-27-2009, 11:36 PM
hyperzone's Avatar
wow... never had any idea that this was that common. At least its comforting to see that I'm not the only one. I'm still happy that its only the trip meter.
You see, I only drive my car a day or two each week so, I didn't notice how much driving I was actually doing. I was getting my gas milage using the trip meter and it kept getting worse.... went from 16-18mpg to 14, to 10, and finally to 8mpg when I finally realized it was the trip meter. I had been checking out all kinds of things like my tire pressure, brakes, valve lash, air filter, checked exhaust for leaks, and even used autotap for a couple of drives looking for any sensor issues and found nothing (and the car drives great - hehe)... I was starting to wonder if I had a fuel line leaking somewhere that was wasn't obvious.
Anyway, does that trip meter come out by itself or is it not removable? I'm sure if its removable I can find another one in a local junk yard.
Old 04-28-2009, 07:14 AM
shbox's Avatar
The cracked gear on mine is on the odometer shaft. That particular gear drives the trip meter. Just grab the whole assy, but check the gear, first.
A secondary concern about getting into the dash is shattering of the top dash cover when you take it off. It is an expensive piece, now.
Old 04-28-2009, 08:30 AM
Bad_tx_Z28's Avatar
^^ yeah.. that happened to me. Talk about being pissed off.
Old 04-28-2009, 09:18 AM
LaVy's Avatar
x3 never again
Old 04-28-2009, 04:25 PM
hyperzone's Avatar
mine is pretty much destroyed already. hehe... Surprised somebody hasn't made some sort of replacement for those out of something better like metal, fiberglass, rubber, or something...
So, that gear your referring to is independently removable/replacable? Or will I have to swap the regular odometer along with the trip meter?
Old 04-28-2009, 05:09 PM
1996firebirdformula's Avatar
Question
Both of mine work good.
Old 04-28-2009, 05:24 PM
shbox's Avatar
The gear just slides off the shaft. Just pay attention to how it is assembled and all will be ok.
Old 04-28-2009, 06:25 PM
sweetbmxrider's Avatar
haha mine does the exact same thing. i wish i saw this before i threw it all back together with the 6le overlay and leds. damn.
Quick Reply: Trip odometer is not working
