TIAL, Turbosmart, Synapse.....OBX??? Looking for WG
Looking 2 buy a WG thats 44mm or bigger. Does / has anyone run a OBX with success? I know there off brand and prob out of the country manufactured, just thought id ask. Anybody have a quality 44+ MM wastegate they wanna off?
ive used more than my far share of Tials. never had a problem with them. they were pretty much the standard when i got into the turbo game years ago.
turbosmart makes a quality product as well but i dont have as much experience with them as Tial. same deal with JGS.
now OBX, or any CHINAGATE, why do you want to risk boost creep or worse? the couple hundred saved probably wont cover a new motor after the gate doesnt open and you have 30+lbs hitting the motor. can happen to all of them but i think your chances are higher with a knock-off. good luck
I wound up getting a 50mm WG, made by innovative turbo. Nice wastegate. Company was a local buisness around here for a while, i think they are closed now. Basically is a turbonetics unit with a different looking cap, from what I can see.
true .. but once you start running extremely large turbos and small gates .. it doesnt regulate boost as effectively because there's a lot less backpressure.
Its probably a street car that obviously needs to control boost. if its a full drag car, you could effectively apply this theory because they run ***** to the wall as much boost as the turbo can give.
