compression test
compression test
Can someone tell me which relay or fuse to disable so i can crank the engine over with out it starting. I want to test compression in a cylinder.
I have one cylinder that the threads on the spark plug are oily. I think its causing a misfire at idle. The plug doesn't really look fouled though just oily threads. Its number 8. I also notice the engine has a funny knocking noise when it misfires at an idle but only if its in gear. If i give it any throttle the knock goes away??? odd huh?
