Thinking of going TH400
OK guys. Ive currently got a T56 in my car and am thinking of swapping to a TH400. My question is, who here is running them, with what stall and what rear gear, tire size, and what is your RPM at lets say 75 mph? I know they dont have any lockup, and that is my only worry. Ive currently got a heads/cam car (specs in sig) with a 4.10 gear, and plan to keep with this gear, and go to a 28 tall tire. Please, any info or recommendations are appreciated!!
At 75 MPH you'll be at 3899 RPM with 4.10's, 28" tires.
Rear gear x 355 x MPH / tire diameter = RPM
(FYI- 355 is for a high stall converter and unlocked, a lot of calculations use 336 but thats more for manual transmissions, locked up converters or stock low stall.) And for overdrives it's rear gear x OD ratio x 355 x mph / tire = rpm.
tals7
400th great for drag car but if drive on street you should look into 4l80/4l85e swap.the swap is easy a is money well spent .they are also just as strong as th400 but way better on street.
I agree with the above, If you're going to drive it everyday, the 4L80 would be the way to go.
I'm moving from a T56 to a th400, but my car will not be daily driven. I already have the th400, it has a 3200 precision stall in it. The car will be on a 28'' tire with 2.75's in the back. I'm going with a low gear because I will be running against bikes and what not on the highway.
do keep in mind also that th400's are known for useing a lot power to turn themselves, on average 150 to 200 horspower.
an aquaintance had a 400 with a 3200 stall in an 04 gto with a 408, he drove it daily for a while, loud exhaust and all. after not long he hated it and just recently switched back to a t56. he was at roughtly 3000rpms at 65mph
every one ive ever seen engine dyno and chassis dyno numbers for did. Thats allowing for rear end accesories. Its that high IMO. Its been my experiance they eat more power the more built up they become.
everything ive heard is they suck more power than most. really the only way to find out would be an engine dyno with a couple different trans behind it. my .2.
Built408, whats your estimate for their power consumption? Are you aware of their reputation for it? Not trying to be a dick, im looking for your honest opinion.
