Tire Width and Height
yes it will, just slightly
your original size is 245/45, which means your sidewall is 45% of 245mm
sidewall-- 4.3 in ~ 110.2 mm
radius----12.8 in ~ 326.2 mm
diameter--25.7 in ~ 652.3 mm
circ.-----80.7 in ~ 2049.3 mm
revs/mile-785.0
so with 255/45 your side wall is 45% of 255mm
sidewall---4.5 in ~ 114.8 mm
radius----13.0 in ~ 330.6 mm
diameter--26.0 in ~ 661.3 mm
circ.-----81.8 in ~ 2077.5 mm
revs/mile-778.0
revs/mile-785.0
revs/mile-778.0
revs/mile-785.0
revs/mile-778.0
revs/mile-785.0
revs/mile-778.0
thx jason
yeah. most dont realize it cuz all they really care about is that first number... when in reallity both affect the way your care rides and drives... gas mileage and final gearing
it's a much bigger issue when you calculate everything that it entails going from 245-45 to 255-45; This small change at what you can call a mere .3 inches will make your ABS/Emergency Brake light go off if you're running 285/40 and larger. Just a heads up.
I was curious also because I'm changing my wheels/tires soon......
I stumbled on this in my search, it seems to be close to other info I have seen.....
http://www.1010tires.com/TireSizeCal...bmit&reset=yes
