nitrous question
nitrous question
if i put nitrous on my stock 98 z28 camaro A4 how much would my motor be able to handle without hurting anything cause i have a guy that wants to sell me a system for 250 and he said it would be able to handle a 150 shot all day long which to me sounds a bit crazy i could see a 50 shot maybe even a 75 but not 150 shot
Well, they say a stock ls1 can handle a 150 shot, with a new fuel pump. I personally wouldn't push it, but anywhere from 50-100 would be fine and you could use the same fuel pump. It'll take the 150 shot, just needs a few slight mods.
I run a 150 wet kit, and I havent had any issues. I personally think as long as you set it up right, have all the right stuff, and pull the timing you need, it will be fine. With whatever kit you go with, make sure to have a fuel pressure safety switch, I use a window switch, but some auto guys dont, I would. NEVER run it with TCS on, thats just a bad idea.. but should be fine. N20 does not fix a motor, so if its already burning oil, or not running top notch, I dont suggest you install anthing until you fix it, BUT if you know your running good, then I look at it just like anything else, it makes power..
Supporting mods, and TUNING. Otherwise no real problem with a 150 WET shot. Like mentioned, it won't fix anything and its going to emphasize any weak spots in your motor. Think it through and do it right. Then enjoy the 470 ft*lb.
Yeah buddy, gotta love that nitrous torque curve. I have seen some serious torque being made just off a little bit of juice. Like these guys said, just be smart about it and don't rush into buying the first thing that comes along, make sure it is what you want and need.
Guest
Posts: n/a
IF the car is completely stock then you could get awway with a 100hp shot without a problem. You could even go to the 150hp shot but thats about the limit of the stock engine components. Being that the car is a 98 you might want to upgrade teh stock pump to a racetronix unit for that just incase senario.
-Chris
-Chris
-Chris
-Chris
Guest
Posts: n/a
The Factory pumps < from what we have seen > are only good to around the 480rwhp mark so if you plan on making over that with nitorus i'd defiantely upgrade the pump. Also with a cam if it has been tuned and the timing has been adjusted you will need to take out the appropriate amount of timing needed to support the nitrous as well. As long as you have the fueling and timing to support the nitrous then you could spray up to a 150hp shot on teh car without a problem.
-Chris
-Chris
-Chris
-Chris
this is what had me concerned:
