cc503 cam setup help.
i bought a cc503 cam, i wanna make sure b4 i order if i can run this set up. for the springs i got Edelbrock 5792 Valve Springs, Single, 1.550 in. Outside Diameter, 1.070 in. Coil Bind Height, Set of 16. and for the rr,COMP Cams RP1417-16, which is Rocker Arms, Stud Mount, Roller Tip, Steel, 1.52 Ratio, Fits 3/8 in. Stud, Chevy, Small Block, Kit. what do u guys think about it? thanks
I have a CC503 cam-only LT1. I did a lot of research and I found that the best spring for the money for my build was the Crane 10308 dual spring kit. Drop in replacement and it should handle ~.600" lift. Works great in my car so far.
+1 on going with 1.6 ratio rockers over 1.52.
Springa are not where you want to go cheap at.
I ran the 10308 kit for about two years daily driving a custom 22x/23x cam with .570 lift on both sides. For a mild cam it is hard to beat. Peaked at around 6k just like they said it would with no sign of valvefloat.
its the money im worried about, the springs 10308 dual spring kit is`out of stock for 2 -3 weeks thru the company who im getting all my parts. im just going to go thru summit. so far i got the 1.6 rr and the camp cam 503 and ill order these springs thanks guys
ok so i got the Crane 10308 dual be here fri, now i was told that i should change the timing chain what do yall think???? and push rods, i was told i can use the stock rods.
