Rear main write up
Old 05-07-2009, 10:39 PM
00_Z-28's Avatar
Default Rear main write up
Did the search didn't find what I needed. Is there a good write up over how to replace the rear main ( picts would be nice ) ?????? Also I have conflicting evidence do I need a special tool or not I wana get it done right the first time.
Old 05-08-2009, 06:37 AM
NonGoggleGuy's Avatar
I remember seeing a write-up not too long ago. And yes, there is a specialty tool that GM probably uses, but not absolutely necessary.
The seal should pry out with a small flathead screwdriver. Don't worry about mangling the seal, but be careful not to damage the seating surface on the block.
Putting the new seal in: this is where there's probably a tool that makes it 50X easier, but just use an appropriate-diameter piece of PVC tubing that fits into the lips of the new seal to gently tap the new seal into place.
Old 05-08-2009, 02:32 PM
00_Z-28's Avatar
Thanks thats what I was thinking was just PVC would work. I have heard two differnt stories should I use grease or oil to help slide the new seal ino place?
Old 05-08-2009, 04:05 PM
00_Z-28's Avatar
I don't half to pull the pan to replace it right?
Old 05-08-2009, 05:53 PM
loyolacub68's Avatar
The new rear seal from GM comes with a plastic ring to guide the seal on correctly. You don't need the special tool anymore.
Old 05-08-2009, 06:09 PM
collier341's Avatar
heres a pic right after i pulled the old seal out.. i just used a flathead and pryed around until i could just pull it out.. as you can see some oil will leak out
guide the new seal in with the plastic guide supplied.. then beat the new seal in using the old seal ontop of it with a hammer.. thats it! i also put a small bead of rtv around the seal just to make sure
hope this helps
Old 05-09-2009, 12:54 AM
00_Z-28's Avatar
Thanks I got it in hope I did it right haha
Old 05-09-2009, 12:43 PM
00_Z-28's Avatar
Ok so I know I'm beating this to death but I don’t wana half to go back in and do this again. I replaced the rear cover gasket and all I did on that was hold it up there and line it up start the bolts and tightened them all down in a criss cross patter is that ok? and the rear main I just barley started on side then got the other in then criss crossed all the way around till it was flush is that ok? should I tap it in further?
Old 05-10-2009, 02:50 PM
00_Z-28's Avatar
anybody?
Old 05-10-2009, 07:27 PM
collier341's Avatar
do you mean the 4 bolts circled in red?? if so then ya you should be good.
the rear main should just sit flush.. run your hand over it and feel.put a bead of rtv around the rear main if your still worried it might leak.
Old 05-10-2009, 10:55 PM
00_Z-28's Avatar
Thanks I will deffentaly do that
Old 09-01-2010, 05:19 PM
vortechvega's Avatar
those pictures are of a lt1 arent they I need change the rear main seal on my 01 ws6 any comments
Quick Reply: Rear main write up
