How do you delete the oil cooler?
I am doing my TH350 swap so I decided to replace all the seals on my motor since most of them leak anyways
I sat and looked at the oil filter housing/oil cooler and I cannot figure out how to remove it and what to replace it with. I haven't tried doing it so maybe it's self explanitory when I do. Anyways, any tips would be great.
Delete Thread
This thread has everything you need with pics:
http://www.impalassforum.com/vBullet...cooler+adapter
I take it back about the oil filter adaptor. It looks like you need to get one. You can get one from a junkyard or new from Summit.
It didn't cost me a cent
Years ago, I did back to back tests with the oil cooler installed and then removed on my 86 Vette. I drove on the street and the interstate at the same speeds (rpms) for the same distances on the same day. I did everything I could to do an apples to apples test.
What I found was my oil temperature ran 20-25 degrees higher with the cooler removed.
Jake
West Point ROCKS!
Jake
West Point ROCKS!
