Western Members CA, AZ, NV, UT, CO, NM, HI
Removing Cylinder Heads
Old 05-09-2009, 12:16 AM
C5natie's Avatar
Default Removing Cylinder Heads
For those of you who have removed the heads off their cars before, what gaskets other than the head gaskets are needed for the job, and does the same apply with a FAST intake? How long did the job take? Easy? Hard? Just need to do some maintenance and replace the gaskets. Thnx.
Old 05-09-2009, 12:24 AM
BigDaddyBry's Avatar
Unless you have the ARP head studs, you'll need new head bolts too. Can't reuse them.
And it's not hard, since I was able to do it.
It took me a few hours by myself first time.
Old 05-09-2009, 12:38 AM
C5natie's Avatar
Yeah, I'll probably just get some new oem bolts for now. Im gonna try to knock it out in one afternoon, maybe 4-6 hours. Was wondering if its enough time. I can rebuild a steam turbine at work so I hope i can do this easy. LOL.
Old 05-09-2009, 12:52 AM
lowerthanyou00's Avatar
remember all dat **** is torque to yield
Old 05-09-2009, 01:23 AM
Red98a4SS's Avatar
its a 8-10 hour job if you never done it before honestly
Old 05-09-2009, 02:22 AM
Wicked_muscle's Avatar
Probably a lot faster to do on a Corvette than a Camaro.
Old 05-09-2009, 04:09 AM
2003cobraH/C's Avatar
it is easier on vetts!
Old 05-09-2009, 10:04 AM
C5natie's Avatar
Agreed! A Camaro looks like a bitch to do with the motor tucked in more. Other than header clearance I hope it should go smooth. If I remember correctly, the FAST has an o-ring type gasket that you dont have to change? The FAST has never come off after install so I hope the o-ring is still good.
Old 05-09-2009, 10:19 AM
MrElectric03's Avatar
I did it in about 6 hours in the car but it should be alot easier in a vette. One thing that may be good to have is the small gaskets that go under the crossover tube, or just put a little silicone on the old ones.If you plan on doing any other work on the heads in teh future it would be much better to just buy the arp head bolts, they only cost a little more than the gm ones and they are reusable. Ill be posting my set for sale shortly now that ive upgraded to studs.
Do you have the fast intake gaskets or stock gm gaskets?
Old 05-09-2009, 11:12 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
your general maintenence includes removing the heads????
Old 05-09-2009, 11:16 AM
camarojunky74's Avatar
what do you mean maintenance? you are pulling the heads, switching head gaskets and re installing?
Old 05-09-2009, 11:41 AM
2 fast motorsports's Avatar
did you blow a head gasket or what?
Old 05-10-2009, 12:59 AM
C5natie's Avatar
Im using Cometics head gaskets, a bit thinner, 0.040. Just wasnt sure what type the FAST used since I didnt install it.
Old 05-10-2009, 09:38 AM
Well the GM gaskets are green and pretty thin compared to the gsaket area on the fast, teh fast gaskets are thick orange seals and can be reused easily.
Old 05-11-2009, 11:01 AM
C5natie's Avatar
Lets just say its a little more in depth than usual. Plus, I would like the experience so Im opting to do it myself other than a shop.
Old 05-11-2009, 11:59 AM
geovett's Avatar
Wink
It's a , what bigger heads???...dang man, r they better than ur trick flows.......(just put a (turbo or supercharger on it and call it a day)...lol
Old 05-11-2009, 01:26 PM
C5natie's Avatar
Well, its still the Trick Flows but just trying some new things out. As for the supercharger.. umm..lets just say 2010 might be a good year.
Old 05-11-2009, 01:42 PM
ss.slp.ls1's Avatar
Get ARP head bolts.
New cometic gaskets.
Intake gaskets are fine to reuse.
Thread locker.
RTV.
Fluids.
Your first time will likely take you a whole Sat, or both Sat & Sun. That's just how it is, take your time, work slow, do things right. Torque sequence on the heads is key.
Old 05-11-2009, 02:30 PM
93Z28rare's Avatar
Nate's getting the bad *** turbonator in 2010!
Old 05-11-2009, 02:56 PM
C5natie's Avatar
Originally Posted by ss.slp.ls1
Get ARP head bolts.
Thread locker.
RTV.
Fluids.
Thnx, I got most of that except the ARP's, oem's for now. As for fluids, some recommend new oil but do you really get that much stuff in it? Damn, I just did an oil change last month.
Quick Reply: Removing Cylinder Heads
