Looking for 700RWHP
Old 05-16-2009, 10:27 AM
DopdBrd's Avatar
Default Looking for 700RWHP
Just tossing around the idea of selling all my nitrous stuff and going FI. I've been wanting to do it for a long time and now is a better time than any.
I'm gonna do a 383 with either a D1SC or a F1C. Don't really know what heads or cam or anything else.
Is it possible to see that mark? What do you guys recommend as far as internals, heads, cam go? I'm most likely going to go with Lloyd for the Heads and cam then do a single plane with an elbow.
The rest of the car is pretty much ready for it, Dana 60, 4.10's, BMR full suspension, K member, Tick Performance 6 speed.
What do you guys think?
Old 05-16-2009, 12:10 PM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com/projectCars.php
Take a look in my project car section, 700 rwhp is very easy to obtain.
http://www.exoticperformanceplus.com....html?item=798
I have all the necessary parts at this link. For 700 rwhp I would put two Walbro pumps together. Bob
Old 05-16-2009, 12:53 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I think he's building an LT1 setup
Old 05-16-2009, 06:49 PM
elias_799's Avatar
^^ good catch lol
Old 05-16-2009, 09:56 PM
4SFEDZ's Avatar
d1sc will get you there, with good heads and blower cam! buy why not go ahead and get the f1?
Old 05-17-2009, 09:28 AM
RealQuick's Avatar
D1SC will get you there... but that will be the max on an LTx setup. You will need probably ~16-18psi to get there.
I would work on getting your current setup running right as it sits now. The experience of solving your missing power issues now will only benefit you down the road with all the hickups you will experience with FI.
Old 05-17-2009, 09:32 AM
EPP
EPP's Avatar
Oops! Definitely harder to do with an LT1, but all you need is a good flowing set of heads. Bob
Old 05-17-2009, 09:40 AM
DopdBrd's Avatar
So would a F1C be a better choice? I wouldn't want to be maxing out the blower and would want a little room to grow.
I plan on working the bugs out of my setup now. I am just at a point that I need to start figuring out what internals I want to go with on my 383, and I would rather go FI. So, I figured I would get everything matched up for FI instead of for the nitrous that way when the Bottom end is done I can start going from there. Know what I mean? I'd rather plan ahead now and have everything right when the time comes.
Old 05-17-2009, 09:41 AM
DopdBrd's Avatar
I talked to Lloyd a few weeks back when I was going to stay with nitrous, and we were thinking either the new TFS heads or some AFR 227's. Both ported by him of course. And I would also do a Victor E manifold with a 860 Elbow.
Old 05-17-2009, 09:47 AM
RealQuick's Avatar
If you want room to grow past 700rwhp... I'd go with the F1 then instead of the D1.
Planning ahead like you are doing is a good way to.
Old 05-17-2009, 11:02 AM
o2ws8's Avatar
Thers a guy on here named moehorsepower he had an lt1 with 383 and D1 and he put down 700 but I think he used race gas!
Old 05-17-2009, 05:59 PM
4SFEDZ's Avatar
the afr 227's, vic jr intake and a F1 you would be set with plenty of room to grow. you would make 700 not pushing it! you will need to change those 4:10's tho! maybe a 3:54! thats as high as you can go in the dana 60!
Old 05-17-2009, 06:26 PM
DopdBrd's Avatar
Yeah, I thought about that too.
But, this project won't be done for a few years. Like I said, I just need to figure out what internals I need now. Then move on from there.
If anything I may try to keep the 4.10's and then run a 15x10 15x3.5 Billet setup with 325/50R15's year round.
But who knows what the future will hold, LOL.
Old 05-18-2009, 05:30 AM
EPP
EPP's Avatar
I agree with everyone, I would go with an F-1A as if will allow you room to grow down the road, and it won't be worked as hard. It is the same diameter as the D-1SC, but it uses a 5.40/1 gear ratio instead of the 4.10/1 in the P and D series. As a result you end up with a larger blower pulley on the head unit which gives you better belt wrap. The F-1A can also make 3 to 4 more psi than the D-1SC can. Bob
Old 05-18-2009, 08:49 AM
moehorsepower's Avatar
Yup that be me, 383 12lbs of huff made 648 RWHP on pump juice and 722 RWHP on the Fast Gas at 14lbs with a D1 and LT4 Heads
